'99 4WD V6 4Runner - Transmission resistance and hesitation
E brake troubles
This turned out to be my e-brake. The clevis pin had completely corroded and seized causing the e-brake to be slightly on most of the time. The problem compounded when I had a leaking rear axle seal and that axle fluid caused the brakes to stick even more. Since i've replaced the e-brake clevis parts, clevis pins, rear bearings, and rear axle seals, I have no sticking in any weather. The rest of the drivetrain is great!
When i got my 4runner the section of bracket welded on the frame for the pivot point for the e-brake was not even there! It must have broken off some how. I have this mental image of a truck impaled on a large pointy rock. I cut one off a junk car and welded it onto mine and has been fine since 4 years ago.
I summarized every thing i have done with my truck on my web site that you can view here: http://www.craigginsberg.com/safari-battle-cruizer/
I hosed out the drums and brake assemblies with cleaner and really didn't see anything obviously wrong. The shoes were good except one was worn a little more than the other three. The bell housings looked good and the ebrake actuates but still doesn't do much. Its not sticking anymore but I'm not sure how spraying it fixed it unless there was a tiny bit of oil causing all the sticking. odd.
KU MechE,
I'm bumping this thread as my truck has started exhibiting the exact same behavior over the last week or so. I reverse out of my driveway in the morning (no issue engaging reverse) and when I select "D" it feels as if something is holding the truck for a moment. No issues whatsoever the rest of the day, and I tend to stop & restart the truck numerous times every day.
Like you, I have always done all of my own maintenance & repair work (apart from tires, alignments and transmission flushes).
I will take a good look at the bell crank assemblies, but I did replace rear seals & bearings within the last few months.
A few points:
- 310,500+ miles
- original owner
- transmission fluid check this morning while running, hot, and in "P" (full)
- transmission flushed three times (every 100,000 miles) using BG machine & Toyota fluid
- transmission pan never dropped - so filter is original
- transmission always dropped into "N" while at a stop light
- truck driven vigorously for 13+ years
Any additional thoughts?
Andreas
A few points:
- 310,500+ miles
- original owner
Andreas
#25
Andreas,
Check your parking brake system and bellcranks to ensure everything is disengaged. Also, check your rear brakes drums/shoes to ensure there is no axle fluid in there causing the shoes to stick.
post up your results
#26
Then I oiled the pivot points of the shift linkage.
Lastly, I backed off my hand brake adjuster. I tend to keep this at 3 or 4 clicks until it holds. Now its at 8 clicks until firm. This may have been the issue?
I'll report back how it acts in the morning.
Andreas
Big Little Bear
230
11-13-2023 11:42 AM
irv
10-01-2015 09:49 PM
icentropy
09-10-2015 05:03 AM
LJR
09-05-2015 06:02 AM
