7mge swap
Old 01-06-2004, 09:03 AM
Reed23's Avatar
7mge swap
Hey All,
I have an '87 supra donor vehicle and was looking into swapping this engine into an '86 4runner. Does anyone ahve anyinfo or know of any good lionks for this swap? I still want to keep the IFS so I don't know how much help the links with a SAS already done will be.
Old 01-06-2004, 06:58 PM
Serith's Avatar
I could be wrong about this, but i heard you have to lift the body a couple inches(2 i believe) if you have IFS because the oil pan hits. If you have a straight axle you will be fine. I can't help you any seeing as how i have never done it, but i would try www.pirate4x4.com and use the SEARCH button at the top and you will find stuff. If not, try www.4x4wire.com and search around.
EDIT: Also, i think you might need to get electric fans, because the stock ones will not fit.
Old 01-06-2004, 06:59 PM
Todd E's Avatar
Do a search on 4x4wire, it's been done before, but it's a TIGHT fit.
I think the radiator is mounted in front of the supports to get the engine to fit (it is 2 cyl. longer) and that's without A/C.
Have fun!
Todd
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
exporunner
3.4 Swaps
08-03-2015 06:10 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
Gevo
07-29-2015 11:15 AM
GeoRoss
07-24-2015 03:03 PM
Quick Reply: 7mge swap
