| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
4Runner lug nut just spins
__________________
Kyle SOLD:http://www.yotatech.com/showthread.php?t=117624 1995 Toyota 4runner SR5 4x4 - 31x10.50 BFG ATS - MANIK Brushguard with 2 Hella 500s - Custom roof rack with 4 BAJA lights - Vortex Muffler - Rancho shocks all around - WabFab 1 inch body lift - Dual HU - Infinity Kappas in rear - Pioneers in the front |
#2 (permalink) |
Thats a tough one...i'm not sure man...hopefully someone can help you out on that one.
__________________
1997 Toyota 4runner 4x4, 2.7L, Auto, 146k miles, KC Slimlites, Bilsteins, OME 881/890s, Custom Westin Push Bar, Brembo/Hawk Pads, Yakima Gear, Midland CB, 265/75/16 Bridgestone Revos, Limited 5-spoke rims (Custom),Herculined Rocker Panels, Diff. Breather mod,Deckplate mod,4.56 gearing, Pioneer head unit w/Ipod connection and Sirius Sat. Radio. |
#3 (permalink) | |
hmm.. try an air gun, i think the impact will take it off!
__________________
91 Toyota "built not bought" Quote:
#4 (permalink) |
Your best chance is probably with an impact gun. I've had that happen to me as well and that's how I got it off. Not, sure how you would get to it from the rear...You might be able to reuse that stud once you get the darn thing off, but a replacement stud of the same size should work too.
__________________
Logan aka: BBP Kiss my IFS. RB4R Life Member #2 THE ULTIMATE TOYOTA RESOURCE '86 4Runner SR5 22R-E 4" Procomp/Superlift/Rancho 9000x/BudBuilt skids. Downey Header/Magnaflow exhaust, Supra AFM. 315/75R-16 Baja Claws, 4.88's, TrueTrac rear. Rear disk kit/trans e-brake. Addicted Offroad winch bumper/MM 9000 Current pics '06 4Runner Sport 270/65R17 BFG All Terrain KO's |
#5 (permalink) |
I would say impact also. You should exert some pressure to pull on the wheel. Outward pressure should help.
*** WARNING**** Make sure the vehicle is well suported like on a lift. Even on a lift or jack stands, if you push hard enough you can push the vehicle off the lift.
__________________
2000 4Runner Sport, 3.4L, 5 Speed, Custom Front Winch Bumper, Opened intake, K&N Airfilter, BFG A/T LT265/70R16, Bilstein Shocks, FreeFlow Exhaust, Poly Rack Mounts & Swaybar Mounts, Tundra TRDs up front and OME 891s out back. ToyTec Panhard Bar Drop. SS Front Diff Drop. Home-built 2x2 Sliders. ARB rear locker, OBA, CO2 See My 4Runner! |
#6 (permalink) |
GONNE NEED THIS
![]() ![]() and a nice impact and maybe a torch...
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan, 130,000 km 31 bfg a/t auto current build 1987 LWB suzuki samurai. turning 2 into one.. yota axles welded front to back, yota springs , ifs steering box,, this bad boy will not only eat jeeps but toyotas aswell \m/ |
#7 (permalink) |
Another result of a dummy with an impact gun! Some idiot got torque happy with air.
I remove them (like stated above) by getting some pressure pushing out on the nut or wheel. See, there are no threads where the nut is, so as you try to loosen it (with air gun or ratchet), you need to get it to bite on the outward threads that are left. It sould start to turn off. It is not easy, but that's the ONLY way it's going to come off. That stud is trash, so be prepared to replace it once you get it off. By the way, remove ALL of the other lugs off that wheel before attempting (Duh!). Maybe even jam a flat screwdriver or thin prybar behind the wheel to apply pressure.
__________________
"Diverse-Customs" Hot Rods, Street Rods, Custom audio and video installation, sheet metal fabrication, tube work, bumpers, lift kits, just about any kind of custom work imaginable! Visit us at Diverse-Customs.com |
#8 (permalink) |
It soiunds like the splines on the other end of the stud that hold them in to the hub have stripped the hub so the only way to get it off is from the back side or by cutting the nut off, either way the stud will have to be replaced afterwards, and maybe a larger diamter one installed. remember studs are a small interference fit.
__________________
Current POS': 1986 Mazda RX7 TII. Haltech E6x, Koni Yellows, solid motor mounts, 10psi 290ishwhp Stock turbo, and stock intercooler... 1991 Toyota Corolla, AKA Crolls Royce. Sold 1995 Toyota Tacoma! 2.7L 4WD 5SPD. The Purple People Eater:TrueFlow Filter, Bilstein HD's, Magnaflow cat, 2.5" Lift, Bilstein 5150's, 265 Toyo OC A/T's, Hawk LTS pads, Brembo brakes; thats it... For now... 2009 Corolla Sport, 5spd, stock for a lonnnnnnnnngggggggg time. |
#9 (permalink) |
Yep, some idiot with the impact wrench. I'd just take it to a shop, but, I'm lazy like that.
__________________
1996 4x4 3.4L 4Runner on 35's - 6" of lift, MTR's, E-locked, ARB Tacoma Bumper, Sliders and a cut off tail pipe. 1966 FJ40 - SOA with stock springs, stock 1F motor, and a smelly tailpipe. |
#10 (permalink) |
You could centerpunch the stud/lugnut and drill it out. Start with a small bit and step up. This will help keep things centered. Ince you get to a big enough bit the nut will fall off.
__________________
#11 (permalink) | |
excellent detail
Quote:
The Enkei wheels may not be properly designed for the truck. There is such a thing as hub centric and lug centric wheels and lug nuts. I am not aware of Enkei making truck wheels but I could sure be wrong there. I am thinking this could happen again if the wrong combo is in play. Consult a tire shop. Take it back to the idiot that air gunned it down and make them take it off-just imagine if that tire went flat what a pickle you would be in then....
__________________
99 4Runner SR5 4wd 3.4/5 spd- Fact. Rr. Locker/Diff Breather Ext. Old Man Emu lift springs- 881 fronts/890 rears O/M/E shocks- N91s fr./N86 rr. All Pro Off Road welded sliders-prevent body damage! ARB"Taco"bumper/Gamiviti clear lenses/Hella 500s Redline Tuning hood struts/Bushwacker Extend a Fenders all my photos are over on Facebook now-I gave up on photo hosting sorry.... http://www.facebook.com/album.php?ai...5&l=5795132731 |
| Tags |
| 2006, 2008, 4runner, custom, lug, nut, nuts, replacement, rims, rotating, stud, tires, torque, toyota, tundra |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Lug Nut Torque? | rockclimber | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 10-05-2008 11:59 AM |
| 4Runner Rim Lug Nut Type? Conical v. Flanged | psfpilot | 86-95 Trucks & 4Runners | 4 | 08-01-2007 04:30 PM |
| 4Runner Alloy Rim Lug Nut Type? Conical v. Flanged | psfpilot | 84-85 Trucks & 4Runners | 4 | 08-01-2007 04:29 PM |
| Lug Nut ?'s | brendonv | General Vehicle Related Topics (Non Year Related) | 3 | 05-15-2006 01:35 PM |
| Lug nut question | xSLICKx | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 09-16-2005 09:48 PM |
