3VZE idle bounce problem
Old 01-31-2004, 06:59 AM
CRogge's Avatar
Hey guys,
I am having an intermittant, engine warm, problem with my idle where the engine will rev up to about 1250, try to stay, and then drop suddenly to 800 or 900 RPMs then rev right back up. Does this sound like a vacuum prob? I checked what hoses I could and didn't find anything. I also have some hesitation until the engine warms up if that helps. The plugs are new. Thanks for any help, -Chris
Old 01-31-2004, 09:52 AM
AgRunner06's Avatar
Post
It sounds like it could be the TPS.
Check out this page.
The symptoms of a bad or misadjusted TPS are near the bottom of the page.
Do a search and you'll find a lot of info.
EDIT: It probably wouldn't hurt to clean your throttle body. You might as well eliminate the easy stuff first.
Old 03-26-2012, 06:57 PM
hmongyota's Avatar
Hey crogge... i know it has been 8 years already... but i am having similar problems with my 3vze... did u ever figure out what was wrong with it? Was it the iacv?
Eggslinger
06-08-2019 03:32 PM
DrZero
18
07-24-2015 11:31 PM
luckypig44
07-19-2015 11:25 AM
kyletbert
07-17-2015 11:39 AM
shisha1999
07-13-2015 11:09 PM
Quick Reply: 3VZE idle bounce problem
