2000 4runner RPM's wont go down
Old 06-20-2013, 05:47 PM
osin's Avatar
Originally Posted by Hilux_3.0
I am Having the same problem, Just bought myself a 2000 T4R with 150,000 KM. Driving at highway speeds if I let off the gas the RPM is pegged at 1500 then as I start braking it follows the speed back down to Idle. Almost as If its trying to engine brake. I also notice it will down shift as I slow down.
I cleaned the MAF, TB, New mobile 1 ATF ( great stuff), Oil Change, Pulled the EFI fuse, Total reset of the ECU and still nothing. No codes have popped up yet.
Guessing TPS?
Yep, replacing TPS did the trick for me
Old 07-02-2013, 09:08 PM
Hilux_3.0's Avatar
Thanks, I tried replacing my TPS with a new one, Does the same thing... Do I need to put the truck into "learning mode" again for it to register a new TPS? What else could cause this issue.
Thanks for all the help!
mskalmus
05-28-2017 07:51 AM
Avenged
07-09-2015 07:55 AM
Cplmike
07-08-2015 08:47 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 2000 4runner RPM's wont go down
