1999 4runner limited 4wd power steering problems/slipping
Old 10-20-2013, 06:04 PM
plamen_vd's Avatar
Hello there guys and gals this is my first post here so you know i am a roke but hers my problem : My 4runner has about 235k milles and when i got it( not too long ago) i noticed steering was slipping a little bit when the vehicle wasn't mooving .it progressed and become worst so heres what i did to it : I replaced the power steering pump cleened the power steering filter and the belt but no luck got little better for a little bit but got worst again so today i changed the rack and pinion and tie rod ends still no improvement,this thing is pissing me off (i forgot to mention i am using full syntetic atf in the system)
ok guys there is nothing else left for me to change can somebody please help
thanks alot
Old 10-21-2013, 05:10 AM
DRCOFFEE's Avatar
Lower ball joints. Just before they fail they cause binding in the steering system which is why your pump is working so hard. On these trucks, LBJ failure is typically catastrophic. by design, the ball is being pulled out of the socket. Newer runners have the fail safe version. Aftermarket parts typically fail within a year so go with oem.
Old 10-21-2013, 05:12 AM
plamen_vd's Avatar
Thank you i'll try it
Old 10-21-2013, 05:14 AM
DRCOFFEE's Avatar
ball-joint-failure-my-turn
Old 12-30-2013, 07:18 AM
plamen_vd's Avatar
buy the way i changed the pressure sensor and the problem went away i just bought the ball joints and have not replaced them yet
voiddweller
19
05-02-2016 09:10 PM
CJ94yota
07-03-2015 10:14 PM
1badyota350
06-28-2015 06:50 AM
Quick Reply: 1999 4runner limited 4wd power steering problems/slipping
