1997 Toyota 4-Runner Cruise Control Problem
Old 01-04-2012, 02:03 PM
NuclearDeath's Avatar
When I use my cruise control in my 1997 Toyota 4-Runner SR5 Automatic it stops working after about 15 seconds. I can live with out it but it would be nice to have again for long trips.
Any suggestions or solutions would be much appreciated.
Thank you
Old 01-12-2012, 08:04 AM
gdutch's Avatar
Check that all your lights are working. I had a burned out turn rear signal, and any time I activated blinker my cruise would shut off. I think it's because of the burned out bulb altering the circuit, and making the cruise think you hit the brakes.
Old 01-12-2012, 08:13 AM
MKtaco_98's Avatar
Ya just check all your fuses blubs plugs etc, from my experience even a bad master cylinder on my clutch caused the Cruise Control to stop working
Old 07-12-2016, 11:34 AM
FastEddieMSU's Avatar
Cruise Control Problems
I have also been having a problem with my cruise control but the issue appears to be from a different source that the usual fuse, brake light switch or tail light out. I have had three modules fail or appear to fail in exactly the same fashion. The original unit failed by initially working intermittently with it returning to activity after I would stop and turn off the engine. This problem got worse until it would not engage at all. I installed a used unit and it worked just fine for two years before it failed in the same manner. I installed the second used unit hoping for at least two years of service but it failed in two days.
My 4R is a 1996 v-6 automatic with 230K+ miles. Still runs well and I would like to solve the cruise issue.
HELP
Nathan_F
08-19-2015 04:03 PM
83flatt
07-02-2015 10:30 AM
ranma21
06-22-2015 11:55 AM
Briareus
10
08-24-2002 05:33 PM
M&S4X4RUNNER
17
07-04-2002 04:38 PM
Quick Reply: 1997 Toyota 4-Runner Cruise Control Problem
