'01 SR5 Flare Removal
Old 01-01-2007, 04:14 AM
Junior Member
tpg013's Avatar
Looking for some help removing the fender flares on my '01 4Runner. I have to get one repainted and I will save about $100 in labor if I remove it myself.
I did a search and only turned up one thread with some steps on how to do it but the pictures did not work.
Any help is appreciated.
Old 01-01-2007, 04:39 AM
Sponsoring Vendor
Strap22's Avatar
I don't care how careful you are, you will break some clips. Get some before you start pulling them off. Other than that just remove the screws and start pulling. Not that hard to do.
Old 01-01-2007, 12:15 PM
foxtrotuniform's Avatar
A tree removed my left rear flare a couple weeks ago. Broke a couple clips, and damn near impossible to get it back on.
Old 01-02-2007, 06:12 AM
Junior Member
tpg013's Avatar
Anyone else? I am afraid of just yanking on it as I don't want the flare to crack. The clips I don;t care about as I can get new ones.
Old 01-02-2007, 06:33 AM
lee
lee's Avatar
you have to go in from the cargo panel, i believe
i have to install one i got off an 01 that was rolled, thanks to a tree taking mine off.. and the guy who took it off the rolled truck said he went in through the cargo panel.
Old 01-02-2007, 06:35 AM
MTL_4runner's Avatar
Yep, you have to take off the plactic panels on each side of the cargo area to get at the clips to push them out from behind.
Don't just yank on them or you may damage the fender flare in doing so.
Old 01-02-2007, 07:09 AM
Junior Member
tpg013's Avatar
Thanks but I am trying to get a front flare off.
Old 01-02-2007, 07:54 AM
Oops, well same principle, push from the inside out, the clips are the same front and back.
You might even conside removing the fender to make the job easy.
Old 01-03-2007, 04:39 AM
Junior Member
tpg013's Avatar
Bump.
06-01-2021 01:51 PM
09-04-2015 09:27 AM
Sr5crawler
07-31-2015 12:32 PM
coffey50
07-28-2015 10:55 AM
Rkellerman
07-12-2015 08:42 AM
Quick Reply: '01 SR5 Flare Removal
