Yota 3.0's 1992 Pickup Build-Up Thread
Old 05-20-2010, 09:05 PM
  #61
RMA
RMA's Avatar
Great looking pictures man .. hows the truck ,did you get her fixed .. and was it the Maf after all.
Old 05-21-2010, 06:51 AM
  #62
Yota 3.0's Avatar
Thanks RMA.. the truck runs awesome without my MAF plugged in, i am just waiting for a MAF i got off ebay to show up and then ill try it out.. ill keep you updated..
Old 05-21-2010, 07:07 AM
  #63
Swimmerboy2112's Avatar
Whaaaaaa?
Old 05-21-2010, 07:26 AM
  #64
Yota 3.0's Avatar
lol i kno.. every vehicle i have owned that had a MAF would not run without it.. but the 1UZ can apparently. There are even a few guys on lextreme who say it runs better without the MAF (a broken MAF of course), thats where i got the idea from.
Maybe there is a default map the ECU will follow? i cant explain it.. magical gypsy maybe?
Old 05-21-2010, 07:31 AM
  #65
graduatedpine's Avatar
[/quote] .. magical gypsy maybe?[/quote]
haha gotta be it!
Old 05-21-2010, 07:48 AM
  #66
Dipstik_90's Avatar
It was the evil monkey in the closet!!!
Old 05-22-2010, 03:01 PM
  #67
yotafella81's Avatar
Has you MPG changed, gotten worse? if so then it is probably running in open loop fuel trim on a predetermined some what rich A/F mix. Of course i'm not totaly sure abou that, never messed with the 1UZ.....just an idea
Old 06-11-2010, 10:33 AM
  #68
Yota 3.0's Avatar
well i changed the ECU and MAF, the truck still bucks under load.. im getting annoyed its gutless but its amazing on fuel.. so i am still thinking that its running lean.. im probably goning to pull the harness back out.. i hate running it in open loop all the time but thats the only way it has power.. UGH
Old 06-14-2010, 06:09 AM
  #69
stock as possible's Avatar
Did you have to cut or grind your roll pan at all to get the TG bumper to line up in the back?
Old 06-14-2010, 06:49 AM
  #70
Yota 3.0's Avatar
^nope
Old 06-15-2010, 06:33 PM
  #71
toyminator2000's Avatar
Are you using the factory truck fuel pump or did you upgrade it? Maybe its starving for fuel.
Old 06-16-2010, 04:16 AM
  #72
Yota 3.0's Avatar
That is what thought too but the lexus pump only flows a tad more than the V6 pump.. i have a Walbro 255 that i want to put in but ive been reading that my fuel pressure will be too high.. so i dunno..
Thanks toyminator, i hope i can figure this out soon. How is yours running?
Old 06-16-2010, 05:21 PM
  #73
Great so far but I haven't had a chance to open it up yet. I'm using a home made driveshaft so I can move it around while I wait for the custom ones to come in.
Old 06-17-2010, 04:09 AM
  #74
Yota 3.0's Avatar
Thats good to hear. I almost wish i could go for a ride in all the 1UZ swaped runners and trucks to compare it to my truck haha
Old 06-21-2010, 09:26 PM
  #75
RMA
RMA's Avatar
any luck yet hows it going.. i dont think its the pump , mines been fine with the 3.0 pump all this time and i floor it every chance i get.. i also read the two pumps are almost the same ,dont remember the exact numbers though.
ofcourse the 4.0 pump wont hurt neither.
and i can tell you my truck wont burn out right now ,well not on dry pavement that is .. but once its going 20-30mph it really hauls ass ,it jumps and flys.
good luck man ..
Old 06-22-2010, 07:27 AM
  #76
Yota 3.0's Avatar
Thanks for the reply RMA, yes i think i have eliminated the fuel pump as my issue.
I just found out that the LS400 has smaller injectors than the SC400 so now im looking for a set of SC injectors because my engine is from an LS but my harness and ECU are from a SC. When i had my MAF unplugged it was fast, 1st gear would spin my 35's on dry pavement just from punching it on a roll so i KNOW im lacking power.
lol check this pic out:
the front tires kept sliding so i just jammed a rock in there
Old 06-22-2010, 08:05 AM
  #77
Z's Confederate Toy's Avatar
Thats pretty much awesome
Old 06-22-2010, 08:14 AM
  #78
RMA
RMA's Avatar
cool pic man .. pm toyminator he was parting out 2 sc400's he may have them.
i have some but not a complete set .
Old 06-22-2010, 09:23 AM
  #79
Yota 3.0's Avatar
Haha thanks man!
thats great news, i will PM him right now.
Thanks RMA
Old 06-22-2010, 06:46 PM
  #80
I read somewhere on lextreme that Supra TT injectors are even bigger than the SC400 ones. Not sure if the Factory Lexus ECU will take advantage of that though.
Quick Reply: Yota 3.0's 1992 Pickup Build-Up Thread
