Daenerysdad '93 DIY Blazeland long travel
Old 11-08-2013, 02:33 PM
  #41
bone collector's Avatar
Thank you both for your service and sacrifice to our country
Old 11-08-2013, 02:39 PM
  #42
Teuf's Avatar
Semper Fi Mac.
Old 11-08-2013, 02:40 PM
  #43
Daenerysdad's Avatar
Anytime Collector. Jerd, that flight line, if it gets any bigger, is gonna push right into Miramar road! So have most of the phrog squadrons switched over to the osprey? And how are your ears from all the f-18 touch and goes!? Man, I tell you what, I lost quite a bit of hearing from 4 years of those things taking off 200 yards away... All I can say is wear your cranial down with the muffs on all day, our you'll regret it in a few years.
Old 11-08-2013, 02:44 PM
  #44
Oh, and Teuf, those bars rock! It's like I'm riding a wheelie everywhere I go! Well, in the sense that I only feel steering inputs, and bumps that my rear tires go over. Now it's time for the 63" spring swap!
Old 11-08-2013, 05:04 PM
  #45
BlazeN8's Avatar
Yeah, 22mm torsion bar just don't have a high enough spring rate. You need 24mm-26mm. Glad to hear your dialing in the suspension.
My experience with the Chevy 63"s (on my 1986 Xtra Cab P/U) was it resulted in 5" of lift which was too high. I took off the overload spring and did a shackle flip to the top of the frame. I also took out the middle leaf spring cut it down and put it on the bottom. Then I added about 150lbs of ballast. After all that I got it to sit at 3-1/2" of lift. The ballast helped with the weight transfer and allowed the rear to settle down. Another drawback is the Chevy springs don't have much of a backbone and axle wrap and wheel hop are a problem. I built some traction bars but then articulation and ground clearance suffered. Overall I am not sold on the Chevy 63.
Old 11-08-2013, 05:14 PM
  #46
Teuf's Avatar
Glad there working out..........
Old 11-09-2013, 07:35 AM
  #47
Kingjerd's Avatar
Yeah after the last hangar where the road starts to turn to the left then go down hill, right before the down hill is our new hangar. We are pretty far away from the 18's, thank God! Most of the phrogs are gone, we have one squadron left with them. All the rest are indeed osprey. These Ospreys though, man, they are definitely a different breed. FUN to ride in!!!
Old 11-10-2013, 08:17 PM
  #48
ToyoTech559's Avatar
good to see another blazeland LT kit. cant wait to see what you do with it
Old 11-16-2013, 05:43 PM
  #49
Ok,some lame-o updates. Few pics of my rear bumper build. Was tired of how long it was taking to TIG everything, but man, those welds look nice when yo get Em right! uh, main tube welded to frame mounts! And almost everything TIG'd together.
Attached Thumbnails Daenerysdad '93 DIY Blazeland long travel-63b990fb-69b3-486c-9d95-d4f6eab947da-6198-00000b3320806fb6_zpse55b923c.jpg   Daenerysdad '93 DIY Blazeland long travel-ba661022-e383-44e8-8da3-8c631383190d-6198-00000b31942c098f_zps37d7ad32.jpg
Old 11-16-2013, 05:52 PM
  #50
And heres about 2/3 of what a perfect TIG weld looks like! Too bad that one was under the receiver and it's getting covered in paint and everything primed in poo brown.
Attached Thumbnails Daenerysdad '93 DIY Blazeland long travel-addc5016-ad51-456e-9a7f-f125cd0c7a0d-6198-00000b319ce300d1_zpsf25c8986.jpg   Daenerysdad '93 DIY Blazeland long travel-c84ddad4-7816-4de0-ab33-cf57b42e693a-6198-00000b31a6a3b7e4_zps5d14ad49.jpg
Old 11-18-2013, 06:26 PM
  #51
BlazeN8's Avatar
Nice! I like how you tied into the frame where the the spare tire mechanism mounts.
Old 11-18-2013, 08:04 PM
  #52
Yeah, when I got rear ended, the car went under me and hit my spare, tweaking the carrier beyond use, so I figured use some provided holes to beef up the bumper...
Old 11-18-2013, 08:50 PM
  #53
HighLux's Avatar
I like the bumpers. Your welds are great. Really good. Cant even say for a beginner. I would have never known. Those look pro.
Im sure you will end up with a super awesome truck. I can tell already.
Thanks for the service Marines. My older cousin was a Marine and he was always a bad mofo. Ended up in Force Recon. Think its gone now?
He did 20 years and retired. The only cousin I wouldnt consider getting lippy with.
Old 11-20-2013, 07:07 PM
  #54
Well, there she is boys. Add another one-off something-or-other to the spank bank. Hope you like the custom flat black paint covering the huge dents on the back. Next up... swing-out tailgate/spare tire carrier. Got it mostly drawn up in autocad. Just have to submit my plans to my teacher, and the hacking, smashing, burning, and cussing will begin anew!
Attached Thumbnails Daenerysdad '93 DIY Blazeland long travel-rear-bumper.jpg
Old 11-22-2013, 07:03 PM
  #55
BlazeN8's Avatar
Very nice! Looks to me like your off to a good career start in Off Road fabrication.
I was trying to do a search for "Blazeland" and its coming up with hundreds of threads now. I am creating a bump on threads that are pertinent to the subject. I'm marking them with keywords. I am using "Blazelander2013" if its a rig that actually has a Blazeland kit or good related info.
Old 11-22-2013, 09:58 PM
  #56
Sounds like a good idea Nate. When I was researching your kit on here many of the tags would take me to some guy that from page 1 started a SAS buildup thread and the thread is 46 pages long! I think it'll help out those like me wanting to dig a little before purchasing your kit, but I have nothing but good to say about your product and service so I'd be biased.
Old 12-12-2013, 02:18 PM
  #57
Picked up some Chevy springs from a kid in the welding shop. Off an '88 2500, so gotta pull a leaf or two out whilst I'm cleaning the crud off...Name:  E877D6D2-4605-47D1-9052-8F2DFD386372-2116-0000044DE3A37D19_zps736f91fe.jpg
And started the front hangar and now it's done too....
Old 12-12-2013, 05:05 PM
  #58
kornhuskerwizard's Avatar
Nice looking welds! Anxious to see what the 63's look like. Im planning on doing the 63's but probalbly only 1/2 tons.
Old 01-25-2014, 06:47 PM
  #59
Little done here and there. Did my 63 swap over the winter school break but had to spend the first week back getting my shock tower stuffed under my bed. And go figure, didn't take any pictures tuil I was 'bout done Name:  56467CEA-398A-4DEB-BD45-7D47611981E6-1717-000002E6F384AD3C_zps54ed0221.jpg
Size:  34.4 KB kinda like the idea of a buggy when/if this thing ever flops Name:  D6A93996-FDF1-4996-87E1-F20755678F89-1717-000002E6E63C6E8F_zps7518a576.jpg
Size:  50.3 KB As you can see my professionally engineered single shock setup 'tuil I could get the new shocks/mount points set up.. and my axle mounts I plasma'd out on the table for my new bilstien 5125's with 11' stroke. Pretty much sit straight up n down tucked tight under the bed. All I have to say is holy crap. The guys who have done this swap before and say its super soft and crazy flexy weren't kidding! Kinda wanna take it off some sweet jumps!
Old 01-26-2014, 10:54 PM
  #60
BlazeN8's Avatar
On my 86 truck the Chevy 63" spring gave me more lift than I wanted, probably a solid 4" The Blazeland front lift is only 3" so the rear seamed too high. I also found the Chevy 63" had no backbone (being only three leafs) so the axle wrap was horrible. There was quite a bit of wheel hop under heavy throttle. I tried traction bars for a while but that killed the articulation. Eleven inch travel shocks are going to need some bump stops and limit straps. Its tricky to get a long enough shock without making compromises of some sort. Bed cages and your cutting up your bed. Steep shock angle and the shock is inefficient and causes the axle to rotate. Angle the shocks to the center and...... well I'm sure you have run through the pros and cons. Keep us posted on how it turns out.
Quick Reply: Daenerysdad '93 DIY Blazeland long travel
