A2theK's 91' Pickup Buildup Thread
Old 11-10-2013, 06:49 PM
  #101
A2theK's Avatar
Got the axle torn down all the way, went smooth, no broken studs or anything. Found some water in the passenger knuckle but no rust or anything, can't wait to clean her out and grease it back up!
Cone washers were a snap using brass to hit them studs with, steer arm cone washers were a bit more of a pain!
Used the screwdriver/hammer method to get those 54mm spindle nuts off and worked great. Also noticed some previous screwdriver marks : p
And where I'm at now. Still have to clean all the parts out, cut everything off the housing I don't need and sand it down well. Kit will be here sometime next week for reassembly!
Old 01-02-2014, 06:07 PM
  #102
A2theK's Avatar
Extra brackets all cut off and smoothed out.
Primered and painted.
Burning in Sky's Toyota truss.
Grabbed a stock 8" diff with 4.88's out of a v6 4runner with only 150k on it!
Reassembly! Full rebuild kit, bearings, seals, grease.
Torqued and assembled up to spindle!
Locking hubs all tore apart, painted and cleaned up and lightly greased for reassembly.
All put together!!
Drool...
Ordering all the misc I need to complete the SAS when I get my next paycheck in!
Old 02-13-2014, 06:41 PM
  #103
A2theK's Avatar
Well got all my hardware for my SAS, just building up my leaf spring setup and will get started soon!
As for now put on some Hella 500FF driving lights!
Lit up!
I got this stock toyota fog light switch I wired in as well!
And where I mounted the relay.
Super bright and well worth it!
Old 03-15-2014, 06:13 PM
  #104
A2theK's Avatar
Still waiting for a good time to get this SAS started, since this is my DD.. Works busy, as is school so I'll have to plan something soon!
In the mean time I got my tax return and gladly spent it on a new softopper and TG rear tube bumper! Was going to fab up my own bumper but ended up going the easy way. Looks great and super stoked on the topper!!
Old 03-16-2014, 07:22 AM
  #105
junk4u's Avatar
Dude Nice truck... But really like that camaro in the background, always wanted one of those for a long time.
Old 03-16-2014, 08:04 AM
  #106
Gevo's Avatar
Looking forward to see how it all goes in! lots of work
Old 03-16-2014, 08:08 AM
  #107
775Toy's Avatar
Great build. Your axle rebuild looks great. I just finished mine aswell and it feels great to know it's all fresh. Looks like you spent your tax return very wisely my friend.
Old 03-16-2014, 09:03 AM
  #108
A2theK's Avatar
Haha thanks man. That'd be my dads 68' 396 SS, it's a beast out in the streets..
Lots of work indeed but should be well worth it!!
Yeah I love looking at how clean it looks but would rather be staring at it under the truck! Haha. Already in love with this topper and I've had it for like 2 days, well worth the $$
Old 06-04-2014, 05:00 PM
  #109
A2theK's Avatar
SAS Basically finished! Still need to set some bump stops and a few other misc things but super happy with the out come!
Here is my build thread if anyones interested!
https://www.yotatech.com/forums/f152...ow-sas-274848/
Few pics of how she sits now! It's about 3" lift in the rear and around 4"ish up front so planning on grabbing some chevy springs at the local yard to get the back up a bit and most likely be getting some 35's soon!
Also.. Went to the local pick n pull the other day and grabbed something pretty special for only $80!! Factory E-locker with 4.30's, factory switch, most of a harness, and 4wd ecu! Pretty stoked!
Old 06-04-2014, 09:07 PM
  #110
twistedyota's Avatar
That is one hell of a deal, truck looks good
Old 06-04-2014, 10:59 PM
  #111
yota_terror's Avatar
Truck looks great! Good job on the SAS
Old 06-10-2014, 06:49 PM
  #112
A2theK's Avatar
Right? Now I need to decide to sell it or regear it :O
Thanks man! Well worth the time and $$
Well... Decided against buying the 33's because I found a great deal on CL.. A set of Federal Couragia M/Ts on some new Fuel Trophy wheels.. 35x12.50R17.. I was hooked on the wheels and was instantly drawn in haha..
Tread looks around 80-90% and the wheels are in great condition. Both are only about a year old as well..
I had to buy some of those skinny lug nuts with the special socket to put them on which was a little extra $$ but oh well I love the look.
Need a little extra lift in the rear because I can tell they'll rub when compressed
Old 06-11-2014, 04:09 PM
  #113
A2theK's Avatar
Flexing the new setup out! Rear flex is slacking, need some chebbies.. No rubbing at all! Really need to get a less drop pitman arm and get my bump stops in place though!
Old 09-14-2014, 06:03 PM
  #114
JeremyW94's Avatar
Any updates?
Old 10-05-2014, 11:38 PM
  #115
todd83's Avatar
Awesome build. I like your suspension setup before the sas. I think I want to lift mine the same way you did yours. So you had the pro comp shocks, 6 inch trial gear shackles, 2 inch blocks, ball joint spacers, sway bar spacer and 1" inch body lift? Is that right?
Old 10-06-2014, 06:07 AM
  #116
rattlewagon's Avatar
Love those soft toppers!
Old 10-06-2014, 06:13 AM
  #117
A2theK's Avatar
Yup that's right. I had the torsion bars cranked too.. The ride quality was horrible though haha. Idk if it was just me but after installing the BJ spacers no one could do a front end alignment within spec so it ate my old tires up.. I never tried a 4x4 shop though just all the big name shops.
06-01-2021 01:51 PM
crashburnoveride
08-28-2015 09:20 PM
jon.r
07-11-2015 03:34 PM
God's Bounty Hunter
07-08-2015 12:54 PM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: A2theK's 91' Pickup Buildup Thread
