89 2wd 3rz swap
Old 06-12-2013, 01:41 AM
wanab4x4's Avatar
89 2wd 3rz swap
so after much searching and debating .. im posting this thread to simplify the install of a 04 3rz into a 89 22r 2wd pickup street truck. this is gonna be smog legal and bar "CA" legal hopefully
parts consist of this :
04 3rz indv coil engine pink injectors from a 4x4 5 speed
95 2.4 transmission bellhousing
stock 89 transmission 5speed
04 wiring engine wiring harness .and 04 ecu
so my question is if i use a 04 dash will there be a need to use any type of adapter wiring harness? it should plug to the wiring harness and ecu
heres it so far
day 1
good bye burnt out lc engineering 22r
heres the differances in the transmission belhousing and what your gonna have to switch around when u do the swap..
starter is on the other side..
also clutch fork and clutch slave /line uses same throwout bearing
here is a comparison of the 95 and 89 hilux 5 speed transmission .. basically the same but the shifter is located farther back on the tacoma
95 tacoma 2.4
89
more to come tomarrow .. stay tuned
Old 06-12-2013, 09:32 PM
wanab4x4's Avatar
day 2.. engine is in .. had lots of clearance issues with steering and crossmember and sway bar all still hit the t100 oil pan so.. cut them out i did ! lol
as u can see the idler arm sits higher on this side and at a weird angle and hits the oil pan so i just took the 2 bolts out swiveled it down and now a perfect stright steering system like it should have been
Uploaded with ImageShack.us
Old 06-18-2013, 12:19 AM
wanab4x4's Avatar
installed a 04 tacoma preunner dash today into the 89 . fits with slight modification . .. soon to be running .
RatOmeter
10-22-2015 03:17 PM
GeoRoss
07-24-2015 03:03 PM
mYnAmEiSmUd
07-20-2015 06:48 AM
colasurdo
07-16-2015 11:32 AM
hexrain
07-12-2015 01:13 PM
Quick Reply: 89 2wd 3rz swap
