Casebite's 1985 xtra cab build(om617 inside)
Old 12-19-2011, 04:56 AM
Casebite's Avatar
Figured I would post my buildup/swap for others to enjoy...
I found my 85 Yota posted on Craigslist for $800 and it was about 30miles away as well so I couldn't really resist. It had been sitting in a barn for the previous 5 years or so, it had mild front end damage, no rust in the cab, and the engine ran. After talking the owner down to $700 I loaded it up and went home.
when I got it home
the next day I removed the bed
and painted the wheels black, cleaned it up, and drove it around
I sourced a om617 off of craigslist for $300 and a 4x4 labs adapter kit, Thanks Luke!
I sold my 22re 4runner to fund the project, I still miss her...
I dont have a shop or concrete, so in the meantime...
Got the engine pulled
Rebuilt the transmission
Insulated the ENTIRE cab! (Peel &Seal FTW) encapsulated the seams w/ HVAC tape so it doesn't stink in Texas summers
Got the adapter kit and exedy Stg1 clutch installed
Old 12-19-2011, 06:23 AM
Casebite's Avatar
Got the engine in
Fab'd up engine mounts
Made my own oil pressure adapter
Rebuilding my front axle, and adding some armor
V6 calipers, and fj rotors
Installed marlin crawler front axle rebuild kit and brake shield eliminators from trail gear
Brakes installed
2" body lift installed along with some 33x12.50x15
All new front end installed and painted, rattle canned with cub cadet beige from tractor supply
Old 12-19-2011, 06:30 AM
irab88's Avatar
nice. subscribed.
roughly how long has all this taken you?
Old 12-19-2011, 07:52 AM
Casebite's Avatar
Taken around 4-5months working only on the weekends
Old 12-19-2011, 09:24 AM
Casebite's Avatar
More pics
First run to get fuel, Unfortunately I have to change out my fuel fill port b/c diesel nossles are larger than gas, for now I've been using a long funnel
bumper I built, I'm too cheap to buy one
I'll post more pics and some vids later today, but as of now I've put over 1500 miles on the truck w/the swap, I'm averaging 22mpg w/mixed highway/city driving. after x-mass I'm going to install some monarch injector nozzles, maybe a larger turbo to keep boost lower at highway speeds and for more power when I need it. Stay tuned....
Old 12-21-2011, 08:25 PM
775Toy's Avatar
Wow dude looks great , how does she run?
Old 12-21-2011, 08:32 PM
russ_'s Avatar
Very cool project! What do you figure your ballpark investment is so far?
Old 12-21-2011, 09:47 PM
streetlancer's Avatar
Awsome! Great looking truck! I love the paint job, looks factory! Was the body lift necessary for the engine swap?
MORE PICS, PLEASE!
Old 12-22-2011, 02:15 AM
B-yodaful's Avatar
wow what radiator did you use? looks awesome got any numbers of you mpg?
Old 12-22-2011, 04:53 AM
Casebite's Avatar
It's running great so far, just drove it to Oklahoma to visit family. Registered 29mpg all highway on the 300 mile trip, only used alittle over half a tank! So far I have about $5k invested in the truck in parts. I'm using the factory 300sd Mercedes radiator and oilcooler, had to notch the frame and remove the front frame crossmember and extend it forward as well. More pics soon!
Old 12-22-2011, 04:57 AM
Casebite's Avatar
I suggest a min. 2" body lift to clear the engine properly!!
Old 12-22-2011, 01:17 PM
B-yodaful's Avatar
Sweet. did you use the toyota gas tank?
Old 12-22-2011, 02:05 PM
Black_1985_SR5's Avatar
Any videos?
Old 12-22-2011, 05:27 PM
Casebite's Avatar
I'm using the factory fuel tank and hardlines... Some Oklahoma pics
Old 12-22-2011, 06:52 PM
For some reason your 2" body lift sits lower than my 1.5". My truck shows a little more frame than that. Do your tires stick out past the fenders?
Old 12-28-2011, 01:36 PM
Casebite's Avatar
The tires poke out a little on the sides and rub alittle towards the back of the front wheel well only when I full turn. I think the angle of the pic hides alittle of the frame rail b/c it sticks out a good 3-4" after the body lift.
Old 12-28-2011, 03:03 PM
Casebite's Avatar
http://i140.photobucket.com/albums/r...e/db0934fb.mp4
Old 12-28-2011, 03:22 PM
Casebite's Avatar
Old 12-28-2011, 05:26 PM
B-yodaful's Avatar
Video is awesome. I have a about a billion questions but I will wait. it looks good. Could you not just use the toyota thermostat gage?
Old 12-28-2011, 05:36 PM
Casebite's Avatar
I was going to use the factory gauge but I sold the 22r(w/the sending unit) before I started the swap ... I'm eventually going to buy a new factory sending unit and ditch the extra temp gauge and move my boost gauge to it's spot. If you have anymore questions just lmk, I'd be happy to help!
Quick Reply: Casebite's 1985 xtra cab build(om617 inside)
