| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
SpecialScottie's 1985 4Runner Build-Up Thread
__________________
02 KLX300 Dual Sported (Daily Driver) 87 Turbo 4runner STOCK 85 4runner: Automatic marlin5.29 elocker rear end. Rola roof rack. 33" BFG KM2's Build Thread 87 4runner (parts) 95 4runner 2wd auto(sold) Last edited by SpecialScottie; 10-20-2008 at 06:44 AM. |
#2 (permalink) |
looks like a good start and its already making you money
__________________
1988sr5 4.3v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits 1972 stepside jimmy d44/d70 425hp 1995 green range rover |
#3 (permalink) |
cool cool. what are you thinking for a motor?
__________________
Wherever, Whenever, However...Tread Lightly! |
#4 (permalink) |
Wow that thing is clean. Seriously its got a straight body with very little rust, and the interior thats there is in great shape. Look at that dash no cracks or nothin. Looks like a great starter
Hey uh.. if you dont want that change ill have it
__________________
. . . I said lie, for me lying under a process tree . . . . |
#5 (permalink) |
#6 (permalink) |
^^ You can put a locker in anything.
Best mod you can do for a 2WD, IMO^^Nice clean runner Scottie! When you get her running, Lets PLAY!!!
__________________
07 FJ, 6 speed 84 4Runner Last edited by stagger_lee; 10-21-2008 at 09:12 PM. |
#7 (permalink) |
I plan on stickin with the 22re. This is going to become my daily driver so I want to maintain good milage. I plan on purchasing a rebuilt engine as the one thats in there is toast. Ill probably get one of engbldrs cams too
__________________
02 KLX300 Dual Sported (Daily Driver) 87 Turbo 4runner STOCK 85 4runner: Automatic marlin5.29 elocker rear end. Rola roof rack. 33" BFG KM2's Build Thread 87 4runner (parts) 95 4runner 2wd auto(sold) |
#8 (permalink) |
Its all stock except for some 30x9.5 BFG all terrains. I believe the rear axle is the same one as on the 4wds so I wouldnt see a problem with putting a locker in. Although second gen 4runners can be had for about the same amount of money as a 2wd. So why not just start off with a 4wd? Plus you could swap over any good parts you might have invested from your 2wd.
__________________
#9 (permalink) | |
Quote:
. Everything I want is soo expensive
__________________
#10 (permalink) |
Did some rearranging today. I moved the 85 into the back yard where I will have more room to work on it and not have to worry about neighbors complaining that it looks like a junkyard
I also started stripping the outside in preperation for painting. I took off the turn signals and bumper and grill and things like that ![]() I also moved my 87 parts 4runner into the backyard next to the 85 so I can easily transfer parts over. ![]() ![]() Im deciding if I want the chrome bumper and grill off the sr5 87 or the black bumper and grill off the dlx 85. Any suggestions?
__________________
#11 (permalink) |
i would go with the black grille and bumper combo also why not swap in a newer 4cyl motor from a tacoma
__________________
#12 (permalink) |
I was considering that. Is that a common swap? Are new motor mounts required?
__________________
#13 (permalink) | |
Quote:
#14 (permalink) |
^For now, you could put a locker in it, but it would be probably best to wait until you get the 4wd.
You could always put a locker in it and swap the 3rd member when you get the 4wd. That is if the gearing is the same
__________________
Mike 1990 4runner: 3.4 swapped, 5-speed, sas'd, Rear leaf swap, Locked, 5.29's, 39.5" iroks on Beadlocks, Armor'd Longfields, Duals coming soon: My build thread http://www.yotatech.com/f152/904_run...thread-158746/ http://www.treadlightly.org/ http://www.pirate4x4.com/tech/billav...ery/index.html |
#15 (permalink) |
there is a great write up on swaping in taco motors on www.offroadsolutions.com check it out
__________________
#16 (permalink) | |
Quote:
__________________
#17 (permalink) |
Update
Started Sanding the frame today. Its not near as bad as many of the rigs ive seen on here.
but I figured Id at least make it look nice.![]() ![]() ![]() ![]() ![]() ![]() I also started stripping the parts car. I plan on using the entire interior out of this one.
__________________
#18 (permalink) |
Are you keeping it automatic or going 5speed? Every now and then Ill think to myself "man Dan, this would be so much more comfortable if the truck was an auto..." but that thought disappears quickly.
__________________
Download your Factory Service manual HERE! <I>I just finished BUILDING my own 4Runner because I'm too cheap to buy one... go ahead and call me crazy!</I> 1984 Toyota XtraCab 4x4 turned 4Runner in just ONE month. |
#19 (permalink) | |
Quote:
__________________
#20 (permalink) |
Dude what is up with those shocks?
__________________
"I love my 4Runner. Everyone else in my condo hates it! I guess it looks bad next to there brand new 20 or 30 thousand dollar cars that will die before my $600 Yota does, and probably before they're even done paying their cars off!" -Steveycapri Whips: '92 Xtra Cab Dlx V6, '94 Dlx I4 5spd. Camry. 98% of the teenage population will try, does, or has tried smoking pot. If you're one of the 2% who hasn't, copy and paste this into your sig. NOTE: To find the 2%...I'm the other 98%. |
#21 (permalink) |
Dude, that's rude! Don't make fun of his shocks.
I'm sure you don't intend for them to stay that way. Are they taped off for painting surrounded areas or something? Or was tht the PO's idea of replacing the seal?
__________________
#22 (permalink) | |
Quote:
Toyota RED is BEEUTIFUL! I have THREE
__________________
85, 87 (SAS), 88 (on loan), 96 4Runners, all males... 03 Town and Country... female CLIK4PIX |
#23 (permalink) |
I decided to chrome out my shocks for more street appeal hehe
![]() I taped them off to keep them pretty when I paint my frame
__________________
02 KLX300 Dual Sported (Daily Driver) 87 Turbo 4runner STOCK 85 4runner: Automatic marlin5.29 elocker rear end. Rola roof rack. 33" BFG KM2's Build Thread 87 4runner (parts) 95 4runner 2wd auto(sold) Last edited by SpecialScottie; 10-26-2008 at 09:17 AM. |
#24 (permalink) |
I actually dont mind the factory toyota red. But this is a gross mix between red and pink. And the whole thing is peeling and completely oxidized. The last owner did a horrible job painting it too and didnt mask much off
__________________
#25 (permalink) | |
Quote:
I did notice those red door handles...
__________________
| Tags |
| 1985, 1989, 2009, 4runner, 85, bay, engine, kn, parts, pictures, rack, roof, runner, sale, yotatech |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| JGrund85's 1991 4Runner Build-Up Thread | JGrund85 | Build-Up Section | 111 | 09-18-2009 02:58 PM |
| 312necro213's 1990 4Runner Build-Up Thread | 312necro213 | Build-Up Section | 104 | 10-25-2008 03:51 PM |
| My '85 4Runner build | TomCat | 84-85 Trucks & 4Runners | 8 | 02-09-2008 07:18 PM |
| '85 4Runner Build... | Newb | 84-85 Trucks & 4Runners | 83 | 05-08-2006 04:29 AM |
