Vehicles - Parting Out Parting out a vehicle, post it here
Parting out 1986 4x4 pickup - OHIO
Old 06-13-2011, 05:52 AM
6th Gear's Avatar
I also have a 1987 4x4 Pickup that I'm parting out - Click Here for that thread
edit: SCROLL DOWN THE THREAD FOR PICS OF EVERYTHING
The truck has 108k mi and the frame is to the point where I wouldn't bother repairing.
Bed is already gone. 22r is spoken for. Lights are gone.
- Standard cab-SOLD with complete brown interior, bench seat. (No inclinometer or tach in this model)
- entire IFS and rear axle assembly, 4.10's
- driveshafts, transfer and trans.
- gas tank
- stock suspension
- fenders, hood, doors-SOLD with little rust. Fenders would be perfect for trimming for larger tires. Cab is decent, a small amount of rust. - with title-SOLD.
- all glass is there-SOLD
- rear bumper avail, front bumper is too rusty.
- stock steel wheels with blizzak snow tires, 205/70R15-SOLD
Old 06-20-2011, 06:05 AM
6th Gear's Avatar
Tail lights and front bumper signals are gone.
SCROLL DOWN FOR MORE PICS W/ PRICES
Old 07-06-2011, 06:22 AM
6th Gear's Avatar
- doors are sold (still have mirrors and interior panels)
- rear section of the harness is sold (from the cab back)
- face for climate control is sold
Old 07-06-2011, 07:41 AM
cracker_1's Avatar
How much for the dash pad shipped to 81006?? Doesn't look like it has any cracks from your picture, true?
Old 07-06-2011, 08:10 AM
6th Gear's Avatar
No cracks, I'll get some better pictures. There's a couple tiny nicks from the clips around the passenger side vent from when it was removed.
I'm still trying to figure out what to ask for the dash... I just watched one go for $182 on ebay http://cgi.ebay.com/ebaymotors/ws/eB...m=150620475543
but that one was grey, slightly different on top too. I think that one was the newer design from later 87-88 pickups. I was thinking $150 obo for this one... I haven't been able to find any other ones for sale in this condition to see what they're selling for.
Old 07-07-2011, 04:50 AM
cracker_1's Avatar
Not interested in the whole dash, just the dash pad on the passenger side.
Old 07-07-2011, 07:44 AM
6th Gear's Avatar
I looked at the back/underside last night and there IS a small crack that can't be seen when the dash pad is installed in the truck.
$100 for the dash pad.
the crack can be seen in this pic, about 1/2" long
Here's some other pics of misc interior parts for those interested.
glovebox
visors
cluster surround
Update 8-17-11 I had all of these on my camera, finally put them online:
everything you see left in the engine bay is avail.
Charging harness and fuse box SOLD
left to right: coil plug $5
Neg battery cable $5
22r engine harness $10
Main harness $75
All seat belts SOLD
Driver's side mirror & hardware $15 (keeping right one)
Brown kick panels $5 ea
Brown A pillar both SOLD
Door sills $8 ea.
Brown rubber trim pieces:
Around door opening on cab $5 one left
Front of headliner $5
Main dash structure $20
Brown Dash Pad, tiny crack on backside (in front of finger nail in pic) $100
Brown & Black Cluster Surround w/ clutch safety override switch & vent $20
left to right:
Ash tray and metal casing $10
Black DIN storage under radio $5
Brown Coin holder $5
Glove Box and white plastic + Black metal piece $25
left to right and top to bottom:
Steering column trim top and bottom SOLD
Radio/ashtray cig surround trim $10
Rear view mirror/dome light SOLD
relay $ 10
ecm $20
hood release $5
Climate control, knobs (face already sold) $15
right speaker cover, bent tab $5
Gauge Cluster 108k mi. $40
Owner's Manual SOLD
Lower drivers dash piece, dimmer knob $15
visors & clips $25 for all
Cab trim pieces from behind door SOLD
Oh ˟˟˟˟ handle $5
Inside door handles $5 ea.
starter relay $15
shift boot - sold
rusty horn $5
Exterior Cowl cover, white just really dirty, $35
Windshield defroster vent $5
Throttle cable (or is that hood release?) $10 and I have both
Antenna - pending
Interior door panels SOLD
handle surrounds $5 ea.
Window cranks SOLD
22r intake & resonator box $5 ea.
Washer fluid tank w/ pump $15
coolant overflow tank $10
Starter $35
Coil $25
Ignitor $50
Shift knob (prev owner must have worn rings on right hand) SOLD
transfer case knob - good cond. SOLD
Rear Driveshaft $70
Driveshaft Bolts $5 for set of 4 (4 sets total)
5 speed clutch/brake pedal set, hardware $30
Brake booster $15
Hood latch rusty but works $5
OEM mud flaps
Front pair SOLD
Rear pair w/ brackets SOLD
5 sp Transmission 108k mi $225
Transfer case 108k mi $150
Front driveshaft $40
transfer shifter $10
transmission gear shifter SOLD
Speedo cable $20
22R bellhousing $40
Plastic front inner fender pieces $ 10 ea side
Inner fender Rubber flaps that cover gap between body & frame $5 each side
OEM fusty fenders, good for trimming for big tires on a trail rig, not much else. sold
Hood, rusty underside $25
Rubber gas door to tank neck filler what's this thing called? Sold
gas tank $35
Steering stuff:
Pump $40
IFS steering box $100
Shaft $15
Steering wheel $25
Column $25
ignition w/ key $15
turn signal lever and wiper lever & assembly SOLD
Front Diff SOLD
parking brake lever assembly $15
wiper arms (surface rust on top) $5
Wiper motor $20
front bumper end caps. (I cut the metal bumper down to get these off, buyer will have to deal with the rusty bolts)
$10
Old 07-28-2011, 06:27 PM
bkubisht's Avatar
I need the seat belts, and the clamshell that goes around the steering column. Shipped to 35806. I'm considering the cluster surround too, but big stuff would probably kill the deal on shipping costs. Quote it both way if you want.
Old 07-30-2011, 06:08 PM
bkubisht's Avatar
Also want the interior A-pillar trim, both sides. Not interested in any parts that are cracked or eaten up by the sun though!
Old 07-30-2011, 06:39 PM
85gijunk4x4's Avatar
grille, light buckets, and corner lamps to 08062?
Old 08-05-2011, 08:26 PM
yotaman90's Avatar
5 speed shift knob to 87571?
Old 08-06-2011, 06:29 AM
bkubisht's Avatar
Never heard back from this guy...
Old 08-06-2011, 05:26 PM
me either....maybe he's just working mad overtime at work?
Old 08-08-2011, 09:22 AM
wii_tarded's Avatar
What would you take for the manual hubs shipped 37921? pm please
Old 08-11-2011, 05:12 AM
6th Gear's Avatar
Yep, sorry about that, have not been online much the last week or so. Everybody will be getting a PM today
I also took new pics of almost everything on the truck for sale that I'll try to get uploaded soon.
Old 08-11-2011, 06:01 AM
xxxtreme22r's Avatar
shift boots shipped to 18706 and can you get me a better photo of the relay rod? I know that bottom end is a little rusty so.
Old 08-11-2011, 06:30 AM
4x4jeffyota's Avatar
Hey man, I need an ac compressor if the bearing is still good and 8 rear drive shaft bolts shipped to 72315
Old 08-11-2011, 08:40 AM
ahhh, jeff just remined me.
i need 1 driveshaft bolt, the ones with the slpines on it, and it acts more likea stud. I'll take all 4 though, fronts will work. they should be the ones on the transfer case flange, as the 3rd member ones arent splined.
thanks, 08062
Old 08-17-2011, 05:52 AM
6th Gear's Avatar
The truck didn't have AC, sorry.
Lemme see how rusty those driveshaft bolts are...
Old 08-17-2011, 05:54 AM
6th Gear's Avatar
Shift boots are sold. I have not been home on weekends, gone again this weekend. I'll try to snap some pics of that rod for ya.
Quick Reply: Parting out 1986 4x4 pickup - OHIO
