'88 4runner part out (rolled) Santa Rosa, CA
#33
I haven't herd back from you in a while, was wondering if I can still get the two sliding windows off of the cap. PM me with your address so I can send you the money.
#34
Need parts-46064
Hey Man, I would buy the rear interior panels. Mine have been cut to hell with a PO's speakers. Also I need sunvisors, manual shifter boot, gas door hinge, and center console top and hinges. Thanks in advance for your reply. I'm at 46064.
-Matt
-Matt
#37
Do you still have the door panels? And how about the Window motors and lock actuators? Basically I want to convert my manual locks/windows to electric.. I'm in Sacramento, so I might be able to pick them up, unless you can ship (packaging is a pain, i know)..
#39
Is the trim on the tailgate that says "Toyota" still good? My lock cylinder is froze with rust and my license plate lights are falling apart. I'd need a key to match. Also looking for a non-rusted out rear window channel. The part that the defrost hooks into and the regulators slide in that is attached to the bottom of the window. I'm in 64137.
Thanks!
Thanks!
#40
Alternator plug- It physically plugs into alternator. I need it with about 4" of wire
washer fluid res with sender- I really just need the sender. Has to have outlet nipple
ac hose bolts- I need the two bolts that screw the two ac hoses into the ac compressor
glove compartment- assuming it has both hinges intact
ac/heater face plate
cruise control bolts- two bolts that bolt the cc down in the engine bay
passenger side power window motor
Let me know
Let me know
