4sale 1993 4runner with converted 3.4
this 1993 sr5 toyota 4 runner automatic trans has a converted 3.4L. I have put 20k on the coversion and it has been a very reliable. the engine has been converted by a toyota master technician. although the stock 3.0 A340h transmission has been used causing a speed sensor code that is impossible to get rid of without installing a 3.4 automatic trans due to the 3.4 ecu not accepting the signal. the transmission shifts just fine you wouldn't know other than a code in the ecu like i said i have put 20k on the convert. the
4runner has 144k and the engine has 110k with a reacent water pump and timing belt. the air contitioning, cruise control and power steering are still functional. basically everything functions normally except for the code in the ecu. i am looking to get 4,900 or best offer. any questions at all don't hesitate to ask. the vehicle is located in arvada colorado just outside of denver.vin number
JT3VN39W1P0108979
JT3VN39W1P0108979
i was under the impression if you had a 3.0 auto, it was required to swap the transmission from the donor vehicle for this conversion? i thought only the manual tranny's fit right up to the 3.4...i guess i'm wrong about this?
Jnkml
07-06-2015 01:20 PM
