GT Radial tires
GT Radial tires
Has anybody here used GT radial tires on their rigs before ? I was looking to get a set of their mud terrains. Theres a tire wholesaler near me with some decent prices. Just wondering if I should pony up the cash for some bfg's or go with these. here is a link to his ad.
http://sfbay.craigslist.org/eby/pts/748871935.html
the main problem I see is that the tread pattern on the first two pictures (the ones on top) are not the same tread pattern on the bottom two pictures. so you've already got confusion about what you'd get by buying.
the top appear to be MT rated truck tires and the lower two appear to be all-weather AT rated tires.
I've had two sets of Adventuro A/T's on my rig. They are a good tire. The price is definitely right. The only thing that was an issue with mine, is they seemed to wear out somewhat quickly. I put an estimated 16K miles on each set of tires (I've run through two sets) I must add, that I purchased both sets of 4 used (with 3-6K miles on them) So, with proper rotation, and depending on other factors, you can expect 20-25K life out of them, maybe more. This is also for the AT, not the MT
1uzRunner
63
11-10-2018 03:58 PM
Williamemslie
14
10-05-2015 09:28 AM
