12.5 inch wide tires, what width rims?
what width rim should i run with 12.5 inch wide tires? I just read that need to be 8.5 or wider but, i thought they could be 8 inch wide?
the 8 and 10" rim dilemma faces a few people. If you are talking about the '95 Runner in your avatar, I would go with the 8" wide rims. Not sure what lift you are running.
I have run both sizes on various trucks over the years.
Granted these pictures are of my '81, 8" wide rims with 3" BS, The lower pictures are with 1.5" spacers but I think it might give you an idea of how far the tire might stick out on your truck with a 10" Rim.
Before spacers:
After 1.5" spacers:
In some areas having your tire stick out that far is illegal and some cops like to get guys for it.
It all comes down to backspacing in my opinion...10" wide rims give you more stability but also increase wear on wheel bearings due to the increased unsprung weight....
Before spacers:
After 1.5" spacers:
i didn't realize that with 10" wide rims.
yeah if your tires stick out too far in some place's cops can give you a ticket or even a vehicle inspection notice. you might want to get flare's.
Location: Houston (home), Atlanta (school), Cincinnati (work)
on my street set i run 10" wheels with my 33x12.5 tires and have never had a problem. for my wheelin set (that i sold), i had same size tires on an 8" rim. not sure why really
Wider tires will make it stick out more but the back spacing really effects it the most.
I'm running 12.50 on a 10" rim. I've never had a bead blow, but I have had problems with the tires spinning on the rim. For years I wondered why my tires wouldn't stay balanced. Then I decided to mark the valve stem location on the tire and found they slowly creep on the rims as I was wheeling (aired down to about 12 psi).
I have now done the poorman's beadlock mod and only air down to 17-18 psi and that has stopped the slipping.
anyone run a 15" wide tire on a 8.5" rim or do you think that would be tooo skinny. i have some 2" spacers i can use if i need so backspacing is not a problem.
id go with a 10" wide rim for a 15" wide tire
im going with 325/85 xmls (38.5/13 - 16) and 16 x 8 4.5" bs, with 1.5" spacers.
may throw on my ifs hubs as well
- http://www.4crawler.com/Diesel/Tires...ningTrackWidth
