Fuel pump questions
Fuel pump questions
When I first did this swap, I bypassed the in-tank pump and put in an in-line pump. That new pump sucks! So I was thinking about hooking the stock pump back up and running it to a regulator. What have you guys done for a fuel pump. Oh I cant use a mechanical pump as there is not enough room between the frame rail. Also what are you guys running for fuel lines? Hard lines or braided? I just picked up a bunch of fittings and braided line and planning on re-doing the plumbing. I am just looking for some other ideas. Thanks guys!
That is a great question because I am almost at that stage in my 4.3 build. I am planning on running a fuel pressure regulator b/c I also do not want to run a mechanical. If you don't get a solid reply and/or get to it first I will let you know as soon as I get to it.
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
