302 Transmission and Transfer case set up
I am looking to swap a carbed high out put 302 into my 91 4runner and not sure what transmission and transfer case to go with. I would like to put another five speed behind it and am just not sure the stock one will handle it. And as for the transfer case I guess I will just need to have something that will bolt up the the transmission what ever transmission that will be. Any advice would be greatly appreciated.
im bout to swap a 302 out of a bronco sport into my toyota. using the np435 trans. but check out advanced adapters., they have adapters for pretty much anything.
this is my issue i have a few trans to choose from not sure wich to use with my 289 swap engine is stout well somewhat around 400hp. i got the fspd that the 22re came with dont think it will hold up. ive got a few ford trans tho c4, t5,fmx that i know are n good shape. my ? would be is there a yota trans that i should look into before i make a choice.
mYnAmEiSmUd
07-20-2015 06:48 AM
crashburnoveride
07-10-2015 06:39 AM
302, adapters, bolt, case, cases, ford, swapping, toyota, tranmission, tranny, trans, transfer, transfercase, transmission, transmissions
