Diesel Swaps Diesel engines
om617 swap issue someone help
Old 11-16-2013, 11:22 AM
Yota-Hooker's Avatar
I just started a om617 swap. Motor is already in and all the fuel line is done and wiring is done. I have one vacuum line hooked up to the pump. I have a normal 22r starter and a 600 CCA battery but it won't turn over. Can someone tell me what I am missing.
Old 11-16-2013, 02:13 PM
dmarsh4x4's Avatar
Does your motor turnover if you use a wrench on the crank bolt ?
Does your starter try to engage ?, you need to give a little more info.
Old 11-16-2013, 03:56 PM
My starter hits the flywheel. I haven't done the wrench yet. Idk how to explain it better but its got the crank just not the over.
Old 11-16-2013, 04:12 PM
Stetson_md's Avatar
I dunno what a om617 is so I can't help you buuuut I noticed your in Florida so check out the group in my sig even if your not in south fla and good luck with your project
Old 11-17-2013, 09:34 AM
waltt's Avatar
Try using jumper cables to isolate the problem. Just bypass your hot wire to your starter, Then use a separate jumper wire to engage your starter if that doesn't work try a different starter. Of course you should check and see if the engine actually moves freely on its own first. Good luck
Old 11-17-2013, 01:47 PM
Its moves freely but I did more looking into it and I'm only getting drops of fuel to the injectors.
Old 11-18-2013, 05:38 AM
JayKray's Avatar
So it is turning over, just not starting??
Did you use the manual lift pump to pull fuel up to the injection pump?
Are your glow plugs getting hot? Maybe not "needed" in Fla, but they certainly help starting, especially with a somewhat worn engine.
You can also crack one injector line at a time at the injector, turn it over until you get fuel, then tighten and move on to the next one.
A bigger battery might help, especially when you are trying to heat up the glow plugs at the same time you are turning the starter. Try jumping off another car to see if it makes a difference.
Good luck
Old 11-18-2013, 08:51 AM
I'm getting power from the plugs. I do pump the fuel. I've tried opening one injector at a time. Still nothing. Just doesn't wanna start up.
Old 11-19-2013, 11:48 AM
JayKray's Avatar
What is the "one vacuum line" hooked up to? It's not hooked up to the shut off valve, is it?
Have you checked compression?
Did you ever see this motor run?
Did you check motor timing?
Injection pump timing?
Old 11-20-2013, 02:40 PM
Update the yota did turn over. I'm guessing there was air in the lines. Because I ran the fuel lines into a gas tank full of diesel. I will also be posting a picture of where my vacuum line is ran.
Old 11-20-2013, 10:02 PM
Captain Jack's Avatar
Turned over, did it try to fire?
Old 11-20-2013, 10:04 PM
Turned over for a few seconds.
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
coryc85
09-09-2015 06:24 AM
Alex Bessinger
08-31-2015 09:17 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: om617 swap issue someone help
