OM617 inspection
OM617 inspection
I'll be going to look at an OM617 motor this weekend. It's not in the car anymore and is just setting on a shop floor with the transmission attached.
I'm going to take a battery with me to see if I can get it to crank. Aside from knowing that everything turns freely what else should I look for that won't require tearing things apart?
Open the oil cap and look in there and see if you can se any issues with the cam. Check the oil and make sure its an ok color and not gritty.Really it would be best to hear it run because there are a lot of variables with these things.
I had a trial by fire with my build. I tore down 3. I now have 2 running ones and one in pieces in the shop and a ton of parts. If you have any questions feel free to ask me its all still pretty fresh on my mind.
Well I'll soon be following in the footsteps of you folks who have already performed the mercedes swap. I got my first look at this engine yesterday and it does all turn. No coolant in the oil, no oil in the downtube, a light coating of grease on the intake/exhaust side. I couldn't see anything wrong with the cam lobes that were visible from the oil cap. This was a model that was not equipped with cali emissions, so no EGR to remove.
The guy was only asking $300 so I figured worst case if it's irredeemable I can part it out and maybe break even.
Now I need start cleaning it up and get my hands on a service manual so I can start checking everything out.
Right after we loaded it up we hit the gas station and I couldn't resist snapping a few pictures. I'm sure the folks around me thought I was crazy taking pictures of an engine in my truck bed at night but oh well.
I got it unloaded today; while it was on the hoist I grabbed my camping battery and a set of jumper cables and gave it a crank. It cranked right over with no obvious problem and puffed some gray smoke.
Now on to cleanup and checkout. (and I suppose I need to start a swap thread)
I'm looking into the tdswaps kit. I plan to do a review/writeup as I perform the install. They have been real quick to answer questions and are very professional in their communications. I'm going to try and get the engine running on the ground tho before I spend the money on the kit.
So, you 617 owners where do I get the tool to remove the flywheel bolts? (edit: nevermind I figured out a 12 point 12mm is a pretty good fit, now I gotta go buy one.)
I yanked the transmission off tonight, and noticed a lot of grease in the bell housing... here's hoping it's just a leaky rear main seal.
