All Other Toyota Swaps I4, I6, Lexus V8
4RunnerGuys 4Runner 1uz swap
Old 11-22-2010, 08:16 AM
4runnerguy's Avatar
Finally desided to go head with the project.
is there anyone that sells the motor mounts for this project?
im also keeping the manual 5speed, and all be getting into detail on wiring harness for the people that feel brave enought to do it there own.
All so cause no one has a detailed wiring diagram.
will be posting a vid of what happend to my 3.slow tomorrow
Old 11-22-2010, 03:57 PM
hgill's Avatar
subscribed! Take lots of pictures and all hiccups you encounter... Good luck with this swap! Glad to know that you are keeping the 5spd
Old 11-23-2010, 08:00 AM
4runnerguy's Avatar
does anyone have the pin outs for the 1991 4runner SR5 5speed v6
Old 11-23-2010, 08:20 AM
ChefYota4x4's Avatar
Suwwwwwwwweet! Watching, best wishes!
Old 11-24-2010, 03:31 PM
4runnerguy's Avatar
Old 11-24-2010, 04:23 PM
hgill's Avatar
4runnerguy, whenever I needed help with wiring, I consulted the following FSM:
1990 Toyota 4-Runner Factory Service Manual:
http://rapidshare.com/files/34006966...0.1995.SIL.rar
OR
http://www.ncttora.com/fsm/1990-1995....1990.1995.zip
It has both wiring and mechanical section. The wiring folder has all PDFs which are color coded so you can exactly which wire is what. Other than those, I also consult my chilton manual which wiring section too.
Another Link: http://www.snjschmidt.com/wiring/
For ECU Pin out for 1991 4Runner 3VZE, download the above FSM and look into the section:
Engine->MFI System--ECM
Here is the 1993 Pickup ECM Pinout hosted online (this might be bit different than yours): http://personal.utulsa.edu/~nathan-b...ne/44engin.pdf
Best thing would be if you have wiring section of 1991 3VZE, but I think 1990 would be your best bet for now. Hope this helps and good luck!
Im curious what happened to your 3.0 .. you gotta post that video
PS. Some links were retrieved from: https://www.yotatech.com/forums/f128...-years-156128/
Old 11-25-2010, 03:33 AM
4runnerguy's Avatar
thanks man.
all be posting the vid tonight its a short clip and some pics
Old 04-14-2011, 05:27 AM
Yota 3.0's Avatar
hey man, any updates on your build?
Old 04-24-2011, 05:16 PM
4runnerguy's Avatar
UPDATE finally
got the motor and tranny mounted
Then i had to modify them a bit
This how my bell housing looks like after its all mounted up
now i got to get started on the wiring, manifolds and slave braket
Old 04-25-2011, 03:58 AM
Yota 3.0's Avatar
nice update dude!
Old 04-28-2011, 08:26 PM
RMA
RMA's Avatar
Looking good man .. some clearer pics would be a lot better though
were you able to figure out those diagrams ? if i left out any let me know .
good luck man ..
Old 05-24-2011, 08:12 AM
4runnerguy's Avatar
were does this lead to whats the name of the plug
Old 05-24-2011, 01:18 PM
4runnerguy's Avatar
It runs together with the power to starter
Old 09-08-2011, 07:41 PM
4runnerguy's Avatar
does any one know??
Old 09-08-2011, 08:03 PM
RMA
RMA's Avatar
The harness your using is it from an ls 400 or sc 400 .. is the plug attached to the same harness that goes to the battery or are you pulling it towards the battery...the plug looks like its the oxygen sensor plug.
Old 09-09-2011, 05:07 PM
4runnerguy's Avatar
its goin toward the battery its cliped together with positive feed to the starter
ls400 1992
Old 03-06-2012, 04:14 PM
4runnerguy's Avatar
its been a wild but i got back to fixing the runner.
right now i am having a problem that the motor starts & runs but dies 1 to 2 seconds after?
Old 03-06-2012, 07:43 PM
RMA
RMA's Avatar
check that your ignitors are grounded really well
Old 03-07-2012, 01:33 AM
4runnerguy's Avatar
Is there a ground on them or is the mounting bracket the ground
Old 04-14-2012, 02:24 AM
ToyotaObsession's Avatar
Looking good! Hopefully you get your running issues figured out soon.
Quick Reply: 4RunnerGuys 4Runner 1uz swap
