2JZGTE Swap kit
Are you using a JDM or US engine?
I would not put a w56 behind a 2jz-tte, maybe a 2jze, but not the turbo.
Oh and w56 will go behind a 7m-ge, an r-series trans resides behind the 7mgte...
you can keep it close to ORS 3.4 swap pricing or more convenient I think you might just have a chance to snag a large portion of the Toyota motor swap crowd.
As far as the wiring goes, Toyota has made it fairly easy (relative I suppose) wiring a 2jz in it is no more difficult than doing a 3.4. We will look into the wiring as part of the kit.
we have used both the USDM and the JDM 2jzs. my truck has a JDM motor in it. I would recommend the JDM motors based on cost.
we are using the w150-w154 trans. we think it is the only one that will take the abuse.
This is great info. We have done a couple of ORS kits and they work very well.
Also, can you take some pics under the truck so we can see clearances? (oil pan etc)
Any of the r150-151 or 154 transmissions will work. You are correct the 150 and 151 will bolt directly to the transfer case. I have a modified 154 trans in my truck. I wanted the longest gear ratio available, knowing I would be driving it everyday.
The nice thing about the having big power is you can take advantage of longer gear ratios.
Thanks,
Rory
idahospeed.com
Thanks,
Rory
idahospeed.com
Yup i hear you, right now i have 4.10's with 33's, cause i like the highway RPM's (with 28's it revs way too high, it's not necessary)
I was actually thinking of using a r154 gearset in a r150 to get a nice overdrive when i got a boosted 3.4, so i can run 4.88 gears and still have a low cruising rpm...
I see you do turnkey swaps for $10995... It's a bit more than 3.4 turnkey... but not 3.4 supercharged +urd'd...hrmmmm....
#25
Having owned and/or driven 7M-GTE, 1JZ-GTE and 2JZ-GTE Supras, I can not emphasis enough how fun these engines can make a car (or truck). Each of them has plenty of low end torque for a truck application, as long as you keep the JZ's twin turbos instead of going the "big single" route.
I could get 26 mpg with my 430 hp Supra, not sure why our lighter 250 hp 4cylinder Subaru Outback can't get that kind of mileage.
Very clean install....I want one.
#27
what are the w-150 and w-154 trannies out of? newer taco's? do they bolt up to gear driven transfercases? what transfercase are you using? any possibility of a A340F auto set up?
#28
pricing and contents of the kit.
that is a damn sick swap.. how much for the kit. i can do all the install myself. but i'd like to know how much for the kit. for a 90 pickup v6 3.slow.
#34
honestly, id rather do this swap than the 3.4L
I always liked the idea but figured i couldnt do it, if you put together a kit i would really consider it as an option, but as a college student it would def. be after a little while of weighing the options
#35
#36
#37
Oh and btw t100 and truck motor mounts are the same.
#38
#39
I've always said I will eventually put a 2jzgte in my truck and know it looks like this might be possible. Sweet!!! now the only problem is money. frresh out of college and no money. I do think it wopuld be easier with the bigger engine bay. now my dreams are closerr to reality. eventually that engine setup with 16-18" of suspension travel and 37" baja TA's. I want her to fly!!
#40
