All Other Toyota Swaps I4, I6, Lexus V8
1UZ swappin' my 1999 4RUNNER!!!
Old 07-02-2012, 07:07 PM
Red Wagon's Avatar
subbed
Old 07-02-2012, 10:20 PM
99 sas runner's Avatar
The input shaft is different, I just swapped valve bodys yesterday cause the lexus trans has 4 cylinoides and runner has only 3. I thought I had sensor problems on the motor cause it was running rough and reving slow and had a friend that's done the swaps walk me through what voltages should be over the phone.. everything checked out good, he said to start it with pulling one wire at a time to see if one doesn't change how it runs.. well all of the pass side ones made it run worst so i Started it with the drivers cover off and the drivers coil wire was sparking on the motor like CRAZY! Threw a diff wire off my spare 1uz and I can't even believe how amazing it runs.. revs fast and idles smooooth. I have a new video but the sound quality sucks.. as soon as I don't have customers cars in my shop I'm gonna go crazy on it and finish it.. I miss it like crazy., more updates soon.
Old 07-02-2012, 11:01 PM
CLICK TO WATCH!
Old 07-03-2012, 03:14 AM
  #25
totally a bro
Staff
vital22re's Avatar
This will be my next swap I attempt.
Old 07-03-2012, 10:10 AM
  #26
It's not an easy swap. And anything before third gen 4runners and tacomas is even more work because of fitment.
Old 07-03-2012, 06:53 PM
  #27
Red Wagon's Avatar
As in the engine bay is too small?
Old 09-14-2012, 10:54 AM
  #28
Man4God's Avatar
I believe dimensionally the bay is bigger in 3rd Gen trucks and 4Runners. What I really wonder is if they are wider in the frame rails. Been looking for that info...going to a junk yard to get it measured out tomorrow I think.
Old 09-14-2012, 02:13 PM
  #29
89lc's Avatar
Mine fits pretty well in my 86. The steering rod is close to the valve cover and the ac compressor is close to the frame, but I modified the frame and that put it really close. Everything else fits great and it looks as though it was meant to be.
Old 09-15-2012, 02:59 PM
  #30
Man4God's Avatar
I just did the measurements at the junk yard and the 2nd Gen is 23" between the frame rails where the engine mounts are and the 3rd Gen they are something like 26". When it cools off, I need get out and double check that 3rd Gen number. Over all, I definitely think the bay is larger in the 3rd Gen. Also, the steering setup is way different between the two generations.
The rack is way towards the firewall in the 3rd Gen while on the 2nd Gen, its way up in front about 6 inches back of the core support.
Old 10-05-2012, 03:03 AM
  #31
Vudujoose's Avatar
Looks good man, sounds good as well!
Old 10-05-2012, 07:59 PM
  #32
So I've wheeled it, drove it, rallied it and loved it! I have a bunch of pics and wheelin vids!
Old 10-06-2012, 04:10 AM
  #33
Red Wagon's Avatar
Lets see them!
Old 10-07-2012, 10:27 AM
  #34
click on the first two.
Old 10-15-2012, 12:03 PM
  #35
Man4God's Avatar
I am so jelly. Don't want the SAS cause I don't do that stuff, but the 1uzfe...drool.
Old 01-30-2013, 02:58 PM
  #36
4biker's Avatar
Sweet build - way to knock it out! I'm also in Utah valley and would love to chat with you about the swap - PM sent
Old 01-30-2013, 09:18 PM
  #37
Red Wagon's Avatar
If someone did a frame off build would it e a good idea to cut the front of the gram off and widen it?
Would that be strong enough?
What tranny are you using?
Flying91
45
04-11-2024 04:39 PM
icentropy
09-16-2020 02:47 PM
BeMiceElf
10-10-2015 09:40 PM
Poppie51
07-16-2015 06:16 PM
cyclist231
07-07-2015 12:56 PM
Quick Reply: 1UZ swappin' my 1999 4RUNNER!!!
