1UZ-FE swap into a 1990 2dr 4runner
great thread! can't wait to see this rig complete. you'll have a very unique and bad-ass truck.
wanted to share a small bit of information in case it's of use to you:
on my '90 LS400, i had a hose fail on the underside of the PS reservoir. it wasn't even a high pressure hose, but just a little thing. the hose failing allowed the fluid to leak into the alternator which is mounted right below it, and it ruined my alternator twice before i realized what was happening. afterward i was paranoid of the res. being right above the alt.
you mentioned you may customize the reservoir location, so i figured this info may be of interest to you.
good luck with your build!
#25
Thanks for your encouragement.
thats the kind of scenario i would like to avoid with using a remote res. instead of the buiilt in unit on the LS. Thanks for sharing!!
#28
Anybody interested in a 2010 Harley Davidson?
MMA_Alex
25
04-18-2017 05:07 AM
