All Other Toyota Swaps I4, I6, Lexus V8
1UZ-FE into 94 4Runner
Old 08-31-2010, 04:44 AM
ej1bullet's Avatar
Talking 1UZ-FE into 94 4Runner
ok so i have a 94 Toyota 4 runner sr5 3.0 v6 5 speed 4x4 with a 3inch body lift and want to do a 1uz v8 swap . the reson y i whold like to do it is because the 3.0 v6 sucks !. it lags on pawer it is a bid time gas eater and i also have many problums with it!!!
so i got sum questions!
i whold like to keep my drive train is it possible?? by that i ment my transition and also my transfer case???
also can it still be 4x4??
haw hard is the wiring??
i em verry serious about this swap im ready to star ordering parts !! :w rench:
thanks guys for any info!1
Old 09-01-2010, 10:56 AM
ej1bullet's Avatar
bump
Old 11-14-2010, 09:04 PM
hgill's Avatar
Any update? did you end up starting the engine swap? ... i would be so interested in this swap in the future since you are planning to retain the 5spd.
Old 11-15-2010, 11:35 AM
birdduck's Avatar
drive train=yes
4x4=yes
wiring difficulty=medium
the best rout to take is to find a donor car, 90-93 ls400/gs400 these seem to be the more
popular ones (i used a 90 ls)
parts to order: if you have lots of cash order a complete bellhousing from down under(this being Australia) or supracharged.com. or the cheaper but more work involved
is to buy an adapter or plans for the adapter of ebay.
you can use your stock flywheel/clutch with a little machining to the flywheel.
next step, save up some money to buy off your wife/GF because you won't see them for the next month/year
Old 11-16-2010, 06:58 AM
hgill's Avatar
birdduck, are you required to machine the flywheel regardless if you get the adapter or bellhousing? I have been reading the forums but I'm not quiet getting the difference between the bellhousing or adapter route in terms of difficulty.
Also, this shop is selling bell housing locally in US for $350: http://www.monster-performance.com/m...products_id=30
Old 11-16-2010, 07:04 AM
irab88's Avatar
subscribed just so i can get the link to the swap
Old 11-16-2010, 02:32 PM
birdduck's Avatar
what needs to be done if you use a 3.0(3vze) flywheel is the center bore needs to be increased a few thousands(where it slides over the crank) the holes are close enough that
they just need to be slotted a few 1/32's... now the important part is the depth of the flywheel, this i mean the over all thickness of it, in order for the starter to engage the ring
gear you will need to remove around 5/16 off the back of the flywheel... DO not go more than this or the flywheel will contact the block along the outer edge.. mine has a 1/16 or so gap.. no need to balance it or anything like that. the machine shop i used only charged 75 bucks to do all this.
Old 11-16-2010, 02:34 PM
birdduck's Avatar
sorry yes you need to machine the flywheel regardless of the adapter/bell you use.
an adapter plate goes between the 1uz auto bell and the r/w/g tranny..
google search 1uz to r series trany adapter and look at the images.
Old 11-16-2010, 04:01 PM
hgill's Avatar
Thanks. Got it!
What I was trying to get at was if you used the bell housing instead of the adapter, would you still need to elongate the clutch fork which you did in your swap. I figured you had to do that since you increased the overall length with the adapter added inbetween the bell housing & transmission.
ej1bullet, sorry for hijacking your thread =p
Old 11-17-2010, 06:15 AM
birdduck's Avatar
correct.
don't think its a thread jack just asking questions he may have himself.. either way i am happy to answer any questions i can
just start your own thread hgill..
Old 11-17-2010, 07:40 AM
RMA
RMA's Avatar
this guy ended up going with another 3.0 .. good info though ..
Old 11-17-2010, 08:33 AM
toyminator2000's Avatar
3.0's are so......sigh.......yesterday.
4.0 is the new 3.0!
Old 11-17-2010, 08:42 AM
birdduck's Avatar
i don't think the two could be related... its like what mr. garrison said on south park about evolution.. the 3.0 would be the fish. and the 4.0 the half retarded monkey human.
Old 11-17-2010, 08:51 AM
irab88's Avatar
Old 11-17-2010, 09:24 AM
hgill's Avatar
correct.
Thanks for the encouragement! I will start my own thread once I pull myself together to perform this swap .... right now .. im just a dreamer! .. I got a long way .. I need to learn how to fab n weld ...get comfortable in doing engine / mechanical work ... All I know is I am good at wiring n electrical stuff...
For now, Its so awesome to see other people doing the swap and defining the perfect 'sleeper truck' ... I'm sure I will catch up soon =p
Old 11-17-2010, 12:23 PM
birdduck's Avatar
the wiring is the hardest part of the swap.. get yerself a donor car and get to work man!
the only fab work involved really is the engine mounts, and trany mount.
Old 12-04-2010, 08:55 PM
ej1bullet's Avatar
yha rma is right im doing a 5.0 swap but i found sum more info hear is haw to do a hrness for the 1uz ! http://www.uzswap.com/forum/index.ph...0;wap2:wrench:
Flying91
45
04-11-2024 04:39 PM
icentropy
09-16-2020 02:47 PM
BeMiceElf
10-10-2015 09:40 PM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: 1UZ-FE into 94 4Runner
