All Other Toyota Swaps I4, I6, Lexus V8
1UZ-FE into 1988 4runner 3.0 3vze
Old 04-25-2011, 07:36 AM
  #401
Smitherz's Avatar
Dang it man will you stop giving me ideas about forced induction. I'm trying to stick to a budget! Now I'm daydreaming about how to build an intake manifold - or contemplating building some turbo headers. http://www.youtube.com/watch?v=bZzYsObXm-4
You need to come down to the sandbox here (Oceano Dunes) sometime this spring/summer to play. Better come on down before the environmentalists shut it down.
Old 04-27-2011, 08:09 PM
  #402
RMA
RMA's Avatar
yea ive been day dreaming about a supercharger since i finished this swap
hows the 14th may 14th i can come down there then .. you guys free .
Old 05-02-2011, 10:46 PM
  #403
Smitherz's Avatar
Yep yep I believe so. I have my paddle tires on standby.
Old 06-27-2011, 06:21 PM
  #404
csc89's Avatar
Subscribed!
Old 09-19-2012, 11:36 PM
  #405
TFADeadman's Avatar
Power steering pipe connection
Hi
I bought the 1UZ-FE a few weeks back and i'm like almost done with it , just have 1 problem tho. From what i can make out is i see 4 lines for the power steering . 2 high pressure and 2 low pressure. 1 high pressure is at the pump where the filler bottle is and 1 low pressure coming out or going into the filler bottle. 1 high pressure beside the AC and just below that another low pressure going to i don't know where.
Can someone plz direct me in the right direction of what pipes go where and how to fit them. I bought the motor alone and all the pipes was disconected.
Thanks in advance for the help.
Old 09-20-2012, 06:06 AM
  #406
toyminator2000's Avatar
Originally Posted by TFADeadman
Hi
It depends on whether your engine came from an SC400 or an LS400. The SC's have a remote fluid reservoir and the the LS's have the reservoir build right onto the pump. Then they both have a power steering cooler in the system somewhere.
If you pump is the LS version then all you need is the two lines going from the pump to the steering box (one high pressure and one low pressure). The hoses from an early model v6 truck/4runner without the steering assist option work perfect. IF you have the SC pump then there two additionl low pressure lines feeding the reservoir.
Old 09-20-2012, 11:36 AM
  #407
TFADeadman's Avatar
Thanks for the reply
I'm going to put up a pic for you to see
i'm really confused here. In the 1st pic you see the power steering pump and filler bottle,left side of filler bottle a little on the side ( 1 ) .On the bottom of the filler bottle the 1st high pressure pipe ( 2 ) . On the bottom a little below that 2 smaller pipes almost touching the radiator, that's the gearbox fluid cooling pipes going to the cooler.
The 2nd pic ( 4 ) is a pipe low pressure i presume and ( 5 ) high pressure.Those 2 is what i'm not sure of what it is.Thought it was for the power steering cuz when i blow air through it ( 4 ) oil comes out from the other one ( 5 )
Attached Thumbnails 1UZ-FE  into 1988 4runner 3.0 3vze-img00211-20120920-1735-copy-copy.jpg   1UZ-FE  into 1988 4runner 3.0 3vze-img00212-20120920-1736-copy.jpg
Old 09-20-2012, 11:44 AM
  #408
SHAGGY21's Avatar
U need the high an low pressure lines off of a 88 to 98 v6 4runner or pickup. Or if u can find a 90 to 95 runner pickup v6 that dose not have abs. The newer trucks use the power steering to run the ads. The late 80's v6 truck lines bolt right in. An from ur picture I can't tell what year ur truck is. If it has abs u have to remove it and remake the brake lines like I did.
Old 09-20-2012, 11:50 AM
  #409
TFADeadman's Avatar
Thanks Saggy
There is no abs or adds just the power steering. so those two pipes on the bottom ( 4and 5 ) i can just close up then?
Old 09-20-2012, 11:54 AM
  #410
SHAGGY21's Avatar
What year an model an engine sizve was ur truck to start with
Old 09-20-2012, 11:57 AM
  #411
TFADeadman's Avatar
That's prolly the most important question of all.
It's 1983 Mercedes-Benz 2.4 diesel so it's not a truck but a sedan.
Old 09-20-2012, 12:03 PM
  #412
SHAGGY21's Avatar
Ur gonna have to have custom lines made then. I thought it was going into a Toyota. Don't know or care to know much about euro trash. Sorry man I just hate cars from Europe. Good luck though.
Old 09-22-2012, 11:02 PM
  #413
If your donor engine is from an SC400 it will also have hydraulic lines for the cooling fan going to the front of the engine that you can't use anymore. You need to replace this pump with a fan idler bracket and pulley from an LS400 or Tundra 2uz engine.
Like this. http://www.ebay.com/itm/99-05-TOYOTA...fa8a85&vxp=mtr
Old 10-25-2012, 08:22 AM
  #414
live4soccer7's Avatar
Out of the 3 donors, for a solid axle (84), would model be best to start with? The SC, LS, or GS? Also, are there any preferential years to get them out of? I know they began making them in 89 and around 94-96 they had an output increase (according to lextreme FAQ) and then 98/99 they went to vvt-i.
I found that info here, under variants: http://www.lextreme.com/1uzfe_info.html
I also read somewhere that pre-98 had some/all forged internals. Is this true and if so, does it hold true for each of the LS/GS/SC models starting from 89?
Old 10-25-2012, 11:58 AM
  #415
Anything 96 and newer is gonna be OBDII and would require all of the sensors and evap system to be in place to run correctly. The older ones may throw a code but won't affect the way it runs. The SC is better for a solid axle. (I am no familiar with the GS at all). Some had traction control, some didn't. Avoid it if you can.
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
mskalmus
05-28-2017 07:51 AM
MTLroadierunner
07-15-2015 12:58 PM
Roger Borba II
07-09-2015 05:05 PM
Quick Reply: 1UZ-FE into 1988 4runner 3.0 3vze
