All Other Toyota Swaps I4, I6, Lexus V8
1UZ to 86 T4R 22re Dual Case 4x4
Old 05-18-2013, 08:13 AM
toyminator2000's Avatar
Looking good so far. You will love that engine.
Old 05-20-2013, 11:25 AM
tyes's Avatar
cutting
Old 05-20-2013, 04:42 PM
tyes's Avatar
some M.I.A pics of the swap in process...
22x19 summit, fits like a charm. needs to get the in and out lets modify
[IMG][/IMG]
Old 05-20-2013, 04:44 PM
tyes's Avatar
ebay is your friend on this one, order for a 90 lexus ls400:
[IMG][/IMG]
Old 05-20-2013, 04:45 PM
  #25
tyes's Avatar
found a mouse snooping around my garage. trying to get rid of it. lol
[IMG][/IMG]
Old 05-20-2013, 04:47 PM
  #26
tyes's Avatar
fan bracket comparison:
[IMG][/IMG]
installed:
[IMG][/IMG]
Old 05-20-2013, 04:48 PM
  #27
tyes's Avatar
inchworm
Old 05-20-2013, 04:51 PM
  #28
tyes's Avatar
low low
Old 05-20-2013, 04:54 PM
  #29
tyes's Avatar
deded
Old 05-20-2013, 04:55 PM
  #30
tyes's Avatar
speedometer sensor bracket:
[IMG][/IMG]
  #31
tyes's Avatar
speed sensor has same teeth count and just a tab short. but i think it would work out just fine... just plug and play ...
[IMG][/IMG]
Old 05-20-2013, 04:56 PM
  #32
tyes's Avatar
combined and this is what you get... had to grind it down a little, it was just notch too long..
[IMG][/IMG]
Old 05-20-2013, 05:03 PM
  #33
tyes's Avatar
longg
Old 05-20-2013, 05:05 PM
  #34
tyes's Avatar
weeeee
Old 05-20-2013, 05:07 PM
  #35
tyes's Avatar
weeeee
Old 05-20-2013, 05:09 PM
  #36
tyes's Avatar
weeee
Old 05-20-2013, 06:20 PM
  #37
Aznwolf118's Avatar
There is always the custom bracket, swaping the pulley off the 1uz and putting it on the original 3zv and switching the a/compressor to the other side.
Just need to extend the original AC line
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 05-20-2013, 07:47 PM
  #38
tyes's Avatar
weeee
Old 05-20-2013, 09:30 PM
  #39
Aznwolf118's Avatar
It's actually easier than the shaft mod.
The 3vz bracket was modified and the bracket was just cut and drill. Seemed easy with a plasma cutter.
It clears the stater by about an 1" but everything is a tight fit anyways with the 1uz
Old 05-21-2013, 01:16 PM
  #40
Originally Posted by tyes
Motor sits 5 degrees tilted to the rear, everything did clear up. So I’m not sure how picky I am about that.. Its noticeable but everything does clear. I think it has something to do with the tranny to TC well to horse collar. So we’ll see..
With Duals you will need to cut that horsecollar and probably some of the floorboard.
This is a pic of mine half done.
Quick Reply: 1UZ to 86 T4R 22re Dual Case 4x4
