All Other Toyota Swaps I4, I6, Lexus V8
1989 Pickup 1uz-fe/auto/dual t-case swap
Old 09-09-2012, 11:57 AM
  #141
toyminator2000's Avatar
Originally Posted by Man4God
What size plate is that? 3/8ths?
1/4"
Old 09-09-2012, 04:54 PM
  #142
NorthIdahoyota's Avatar
I ended up making my mounts out of 1/4" plate with the poly bushings 89lc used. The design is a bit different than toyminator's due to my IFS though.
Old 09-09-2012, 05:47 PM
  #143
Man4God's Avatar
Sweet! Then a basic stick welder will do the job. There is an HF 80 amp DC inverter welder that should be able to pull that off with ease.
Love the rig Toyminator.
Old 12-03-2012, 04:42 AM
  #144
Spooled91T's Avatar
1uz swap with IFS
Hey NorthIdaho, do you have a build thread or photo album of your 1uz swap? Most specifically, im interested in how you did your motor mounts and exhaust manifolds around the IFS which I am keeping.. Thanks in advance..
Old 12-03-2012, 05:31 AM
  #145
I don't know who's this is but I saved it when I was researching my swap. You may also want to read some of the swaps done my the user RMA. He's done three of them and all were IFS.
Old 12-03-2012, 04:41 PM
  #146
No, I decided not to do a thread because none of my swap is too awfully original. Just pm me and I can happily answer any questions. I did take alot of pictures during the swap though. for the mounts what I basically did was torch the stock mount off and make a braced platform to mount the poly donuts through. The mount welds to the frame and I also used a small piece of angle to weld it to the ifs bracket. After welding, I drilled a hole for the mounts.
Old 12-03-2012, 04:42 PM
  #147
Hmm, pics didnt work...
Old 12-03-2012, 04:47 PM
  #148
Oh and for the exhaust manifolds I used a cheap set of stainless headers off ebay. To make them fit you just have to move the outermost pipe on the drivers side in and down. Works well and was pretty easy, but I still have a small leak at the collector from my crappy welding. I have pics of that to if I could figure out how to upload them here.
Old 12-03-2012, 05:29 PM
  #149
got it
[IMG][/IMG]
[IMG][/IMG]
Old 06-08-2013, 02:50 PM
  #150
Spooled91T's Avatar
North Idaho, you ever find those pictures of the ebay headers you modded? Would love to see the mods and how it turned out in the engine bay..
Old 06-08-2013, 07:08 PM
  #151
Before, after and 9 months later. My motor is offset 1" but still wouldn't be hard to clear even with no offset. If your engine is lower than mine that would help.
Attached Thumbnails 1989 Pickup 1uz-fe/auto/dual t-case swap-0909121921.jpg   1989 Pickup 1uz-fe/auto/dual t-case swap-0909122037.jpg   1989 Pickup 1uz-fe/auto/dual t-case swap-img_20130608_194037_944.jpg
Old 06-12-2013, 11:05 AM
  #152
yotasavg's Avatar
Welp, finally blew a head gasket in the 3.0 yesterday. It's been a long time coming but I guess I'm officially on the hunt for an LS400!
Old 08-31-2013, 07:45 PM
  #153
driverman's Avatar
love the swap hope to start mine soon
Old 10-05-2013, 08:02 AM
  #154
Can't get the videos to embed but here are a couple of short videos crawling "Double Whammy" at Southern Missouri Off Road Ranch. unfortunately the camera angle doesn't show the ledges and how steep the hill is.
https://www.facebook.com/video/embed...59244714100442
https://www.facebook.com/video/embed...59245224100391
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
coryc85
09-09-2015 06:24 AM
God's Bounty Hunter
07-08-2015 12:54 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 1989 Pickup 1uz-fe/auto/dual t-case swap
