All Other Toyota Swaps I4, I6, Lexus V8
1989 Pickup 1uz-fe/auto/dual t-case swap
Old 10-06-2010, 03:46 PM
  #61
RMP8080's Avatar
What a great idea, using s toyota motor in a toyota truck, sorry lexus motor.
Great build keep us posted................Thanks
Old 10-15-2010, 03:49 PM
  #62
toyminator2000's Avatar
Not really related to the engine swap but I started bobbing another bed. I took 14" out of it just like the last one. It's more than most people do it but I wanted the frame to be the first thing that drags as opposed to the rear valance.
Old 10-20-2010, 06:03 PM
  #63
Lots of welding and grinding.
Old 10-20-2010, 06:18 PM
  #64
yotarob2005's Avatar
Dayum that's nice work, you should see the junk I am trying to pull off. I though I could handle welding in a new quarter after a wheeling incident, lets just say....yours looks WAAAYY better. How did you even cut it so strait?
Old 10-20-2010, 06:51 PM
  #65
Sawsall and air body saw. I just followed the tape line. I learned the last time I did all the bodywork on the truck that it's just easier to buy the correct tools for the job. I always look at tools as an investment.
If you are doing a quarter panel you should have just bought a spot weld drill bit and drilled out all the spot welds.
Old 10-20-2010, 09:08 PM
  #66
mightymouse's Avatar
i so wanna see this ruck when it's finished. x2 on the nice work on the bed bob.
Old 10-21-2010, 04:13 AM
  #67
I used a Dewalt grinder & cut-off wheel. I drilled out quite a few spot welds with a uni-bit step drill. Check out page 27 post 652 of my build thread & you can see what I did. I'm a first timer and thinking that it came out looking like crap. Sorry for the thread jacking.
https://www.yotatech.com/forums/f199...6/index27.html
Old 10-25-2010, 12:59 PM
  #68
Its turning out pretty good so far. I did some light filler work and then shot an epoxy primter/sealer over the whole bed. I still have some skim coat work to do and some dings to fill. Then 2-3 coats of high build primer.
Old 10-25-2010, 05:23 PM
  #69
RMP8080's Avatar
well done guy...........
Old 10-26-2010, 06:49 AM
  #70
birdduck's Avatar
lookin sweet!.. am i the only one with a rusted 1uz? i better get rockin on the body work.
Old 10-28-2010, 06:00 PM
  #71
RMA
RMA's Avatar
^^^ haha!
man dude you do some good body work (at least in photos on the internet it looks good ) , i just welded a broken roof on a 2000 astro and i was making some bigger holes in it with the welder on its lowest setting and .25 wire . in the end it worked out but it was hard .
What are those clips your using to hold the bed together called?
Old 10-28-2010, 07:34 PM
  #72
Originally Posted by RMA
^^^ haha!
They are called sheetmetal but weld clamps. They make it much easier. You still have to just make tons of spot welds and space them out to keep from warping the metal. If you hold the gun on it longer than about 1 second you'll blow through it.
http://www.harborfreight.com/8-piece...mps-44751.html
If you look really close in those pics of the bed you can still see a couple of bad spots where I welded it. There are also about a dozen dings on it to fix.
Old 11-20-2010, 01:54 PM
  #73
My painter sent me some teaser pics from his phone. ˟
Old 11-21-2010, 08:11 AM
  #74
sparks's Avatar
Loving this thread,real nice work there
Old 11-23-2010, 12:24 PM
  #75
It hards to catch Silver on a digital camera but here is a better quality pic of the fender. I think the color really pops in the sun.
Old 11-23-2010, 02:51 PM
  #76
What do you plan to do, if anything, to protect it when wheeling?
Old 11-23-2010, 02:56 PM
  #77
Damn nice work! paint looks great
Old 11-23-2010, 05:51 PM
  #78
Exo. I know it adds a lot of weight up top but I can't fit in the truck with an internal cage and I want to do the best I can at protecting it. I do all the bodywork myself and the paint I chose was a factory color with no special mixes to it should be easy to repair "when" the inevitable trail damage occurs.
Old 11-24-2010, 04:22 PM
  #79
RMA
RMA's Avatar
that paint looks good man .. i bet you cant wait to go out on the trails and scratch her up
Old 11-29-2010, 07:49 AM
  #80
Quick Reply: 1989 Pickup 1uz-fe/auto/dual t-case swap
