swapping auto motor into manual truck
Old 04-22-2009, 06:03 PM
GJCruiser's Avatar
I've come to the conclusion that the 3.4 is the swap foro my dead 3.0 5spd truck. As I search for motors, I concerned about some apparent conflicting info that I accumulated.
Most donors in western CO are in automatic 4Runners. Some threads here have stated the incompatibility of putting the auto motor into a manual truck. Some specific info here states that the auto crankshafts aren't machined for a pilot bearing. The ORS technical info alludes to a similar issue.
However, a trusted Toyota dealership parts guy showed me that there was only 1 5VZ-FE crankshaft part number for the entire run. I also inspected a motor from an auto that had a bearing installed.
Can this be definatively answered or not?
Thanks for all your help.
Old 04-22-2009, 06:11 PM
cadi_daddy's Avatar
just make sure that the donor 3.4l has a pilot bearing hole and you will be fine.
Old 04-22-2009, 07:22 PM
GJCruiser's Avatar
I guess I asked badly the first time. How does one make sure. Are all the engines the same or not? I want to hear it run before its pulled. No yard is going to pull the motor to let me look.
Old 04-22-2009, 07:48 PM
RobD's Avatar
https://www.yotatech.com/forums/f160...earing-137459/
Old 04-22-2009, 11:48 PM
totally a bro
Staff
vital22re's Avatar
all 3.4's have it. ors lies!!
Old 04-23-2009, 05:26 AM
GJCruiser's Avatar
RobD, thanks for that link. That's what I was looking for.
Old 04-23-2009, 08:40 PM
RobD's Avatar
You will need:
-3.4 flywheel, clutch and pressure plate
-3.4 pilot bearing
-3.0 throwout bearing
Old 04-25-2009, 07:26 PM
TMZ
TMZ's Avatar
I used 3.0 pilot bearing, throwout bearing, flywheel, clutch, and pressure plate on my swap.
Old 04-27-2009, 05:28 AM
jskijoe's Avatar
My 3.4 is from an auto 4Runner 4x2 and I used a computer from a manual tacoma 4x4. The engine had the hole for the pilot bearing and the plugs all fit into the computer.
Old 04-27-2009, 09:29 AM
TMZ
TMZ's Avatar
Just because the plugs fit into the computer, does NOT mean the wires are in the right location. End result could be a fried ECU. Toyota used the same plugs on many differant harnesses. They moved the pins around to make them work with individual ecu's. I have a 00 cellica ecu that plugs right into a 3.4 harness. This doesn't mean it will work or not do damage to the ecu or harness.
Old 04-29-2009, 05:08 AM
jskijoe's Avatar
I had ORS do the conversion harness and I gave the vin#'s for both and mentioned the them the differences and talked with Mike about it. I guess I'll just have to wait and see. It sucks that ORS isn't around any more but if it does fry it, I guess I'll find another ECU and and you'll have another customer!
Old 12-22-2011, 07:49 PM
Oso Blanco's Avatar
I just bought a 94 5spd Runner and picked a 3.4L from a 96 auto Taco complete with the wiring and ECU. Do I have to run a MT ECU if it's swapped into a 5spd truck? I've done SBC and 4.3 Chev conversions and never had an issue using an A/T ECU with a 5 spd. If I can avoid spending the extra $$ on an M/T ECU and plugs I'd like to.
Thoughts?
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
vasinvictor
01-20-2016 12:39 PM
Crazy_Guy97
12
06-24-2015 04:02 PM
streetuner15
06-18-2015 10:59 PM
TheManOutside
06-18-2015 03:32 PM
Quick Reply: swapping auto motor into manual truck
