IH2 wiring confusion *PLEASE HELP*
Old 01-10-2010, 08:26 PM
dntsdad's Avatar
Ya I couldnt find an overall diagram for my 92 either like i could my 97 runner donor. I really like the overall diagram rather than all the individuals.
The hard part is in some diagrams I have the plugs are called on thing and on another diagram the same plug is called something else. I am not sure why this is but it really screwed me up for a while until i noticed it. I then started only using the same source so the plug labels wouldnt change on me.
I am not sure what C1 and C3 are. Can you take pictures or post a diagram of the plug and I will see if i have anything to fit your needs. If I see the plugs, i may know how to help you out. Maybe someone will jump on before that though.
Old 01-10-2010, 08:46 PM
dntsdad's Avatar
try looking for a overall wiring diagram for the same year 4runner if you still have access to TIS.
In some of my diagrams for indivudual circuits the plug is called C1 and C2 (i think off the top of my head) and in the overall its called IH1 and IH2.
What I did was grab the full version of Acrobat and open the overall diagram for a 92 4Runner and then in the search box enter iH1 and it found all of them. then I labeled the wires and did the same with iH2.
I then took that to the truck and made sure everything matched and it did perfectly. then labeled everything with blue painters tape and a Sharpie.
If you need the overall diagram for a 92 Runner, I can email that to you but thats all that i have.
Old 01-10-2010, 09:50 PM
yodathespian87's Avatar
I also noticed that if you look up on TIS 92 truck nothing pops up but if you look up 92 pickup truck then all the diagrams pop up. If you can take pictures of the connectors and\ or tell us the color wires and the positions, I will try and tell you what I think it maybe.
Old 01-11-2010, 04:27 PM
Trebor's Avatar
C1
C1 plug
1=white/black
2=x
3=purple
4=x
4=5=green/white
6=blue
7=blue/black
8=black/red
9=yellow/black
10=black/green
11=x
12=white/green
13=x
14=black/red
15=x
16=white/red
17=x
18=x
19=x
20=light green
21=x
22=black/white
23=green/yellow
24=x
C2 plug
1=x
2=green/white
3=x
4=x
5=blue
6=black/red
7=red/white
8=black/red
9=x
10=green/yellow
11=yellow/blue
12=x
13=lightgreen
14=yellow/green
15=black/white
16=x
17=x
18=x
19=green/red
20=black
I hope this will shed some light. My buddy is getting mad at me. He wants his shop back. If i can make this thing fire i can move it to my house and finish. Big thanks!
Old 01-11-2010, 04:42 PM
  #25
Pm'd you. Now are these your 3.0 body harness plugs? Cause its looking like these are your IH1 and IH2 body plugs. Which matches my 93 4Runners IH1 and IH2 plugs. I have this written all down in my thread. I will copy and paste for ya.
Old 01-11-2010, 04:53 PM
  #26
Wiring Diagram!
E5- Connector
1. L-V =Batt to IH1 B-G =Constant power to ECU
2. B-L =IGSW to IK2 B-R =IGSW
3. G-Y =FC to G-Y =Circuit Open Relay To Air Flow
4. X
5. X
6.V =W to IH1 V =Check Engine Light
7. B-W =STA to Stater
8. GR-B =MREL to IH1 B-R =Power To Ignition Coil
9. Y-G =TPC to IK6
10. X
11. W =SIL to OBD2 W =SIL
12. X
13. X
14. X
15. G-W =STP to IH1 G-W =Stop Light Switch to ECU
16. W-L =+B to IH1 W-R = Switched Power
17. Y =PTNK to IK6
18. X
19. X
20. X
21. X
22. X
E6
1. X
2. R-Y =R to IK2 R-B =Park Neutral Switch (Reverse)
3. V-R =2 (2nd Gear?) to
4. Y-G =IDLO to IK2 BR =Data Link Connector to Ground and IH1 Y-B = From Cruise Control ECU to Check Conector
5. X
6. L-W =ODMS to Nothing (ADD)
7. Y =OILW to Nothing (ADD)
8. R =OXS to IK2 BR =OXS
9. R-W =HTS to IK2 BR
10. L-O =ODLP to Nothing (ADD)
11. X
12. LG =L (Low Gear?) to
13. L-B =ACT to IH2 B-R A/C Amplifier To Engine ECU
14. X
15. X
16. X
17. R-G =TFN to IK2 W-B = Neutral Position Switch
18. L =4wd Detection Switch
19. L-R =Low 4 Detection Switch to IK2 GR =Low 4 Detection Switch
20. B =
21. X
22. G-O =SP1 to IK2 =G-B =speedometer
23. X
24. BR-Y =OD1 to IH1 Y-B From Cruise Control ECU to Check Connector
25. L-Y =AC1 to IH1 L-B =A/C Amplifier To ECU and Transmission
26. X
27. X
28. X
IH1
1. W-B- GND for the transfer case
2. X
3. V - To Check Engine Light
4. X
5. G-W- Stop LightSW to ECU
6. L - FP In check Connector
7. L-B - a/c amplifier to ECU and transmission
8. B-R - Anti Lock to Check Connector
9. Y-B - From cruise control ECU to check connector
10. B-G - Constant power for ECU
11. X
12. W-G - Ground for ECU
13. X
14. B-R -Power to ignition coil
15. X
16. W-R - Switched Power
17. X
18. X
19. X
20. G-L- Speed sensor
21. X
22. B-W- Starter to starter relay
23. G-Y - Circuit open relay to air flow
24. X
IH2
1. X
2. G-W - Transfer Oil pressure Sw
3. X
4. X
5. L - a/c amplifier to engine ECU
6. B-R - a/c amplifier to engine ECU
7. R-W - trans. R-W
8. B-BR - trans. B-BR
9. X
10. G-Y - ADD indicator SW to 4 wd light
11. Y-L - Oil pressure sender
12. X
13. G-L - Vehicle speed sensor
14. Y-G - Water temp.
15. B-W - a/c amplifier to engine ECU
16. X
17. X
18. X
19. G-R - trans G-R
20. B - ignitor to a/c amplifier
https://www.yotatech.com/forums/f160...13/index6.html
Old 01-11-2010, 05:03 PM
  #27
Oh by the way I have not finished doing my wiring, so this has yet to be proven correct. Take it with a grain of salt. And if anyone has corrections feel free to let me know. Its finally warm enough for a few days I may get out there and play around.
Old 01-11-2010, 08:24 PM
  #28
dntsdad's Avatar
Trebor
Post up your email and I will send you the 95 Runner diagram that I used. It was a perfect match to my 92 pickup.
If you are looking at the individual diagrams like this one for the engine control notice the connection that I have in the red rectangle. Notice how its called C1 on this diagram.
That is the same connection in this overall wiring diagram for the 95 Runner. Notice its called IH1 on this one.
Same connection but different name. I dont really understand why and it took me a while to figure that out but now I have everything in the 92 tagged where I am confident that i know what each wire does. We'll see if it starts though!!
Old 01-12-2010, 05:29 AM
  #29
Trebor's Avatar
The E5 and E6 are you saying these are the IK2 and Ik6
Old 01-12-2010, 07:04 AM
  #30
IK2 and IK6 are the 3.4 body harness connectors. E5 and E6 are the connectors to the ECU. So when all is said and done the E5 and E6 wires go into the IH1 and IH2 body connectors and the engine harness. You are taking the body harness and blending it with the engine harness at that point. (Does that make any sense?) E5 and E6 plug into the computer, some of the wires go to the body and some go to the engine. Hence the splicing.
Old 01-12-2010, 03:54 PM
  #31
dntsdad's Avatar
Trebor
I sent all the files. Check you email.
Jason
Old 01-14-2010, 07:54 AM
  #32
Trebor's Avatar
So Ive run out of time is there anyone out there building a harness now. If so please let me know.
Old 01-14-2010, 04:06 PM
  #33
dntsdad's Avatar
contact yotaman.
Click his name in the sticky section of this section and use that to email him.
He is a super nice guy and very knowledgeable. I think he is getting about $375 or something for a harness.
Old 01-18-2010, 05:41 AM
  #34
Trebor's Avatar
Ok the wiring went good this weekend. It started and also sounded very good. But there is no throttle responce it bogges. It also smells very rich. Mass air flow? O2s? Any thoughts out there? On my Ik2 I have a white/red wire. For some reason i can't find a home for.
Old 01-18-2010, 08:52 AM
  #35
dntsdad's Avatar
Look at the diagram above. On the 3.0 the White / red is the feed from the EFI fuse.Verify by putting a meter on it with the key on and it should have 12V+. Leave the meter on the wire and then pull the EFI fuse from the fuse panel on the passenger fenderwell. That wire should lose its 12V+. You should also be able to pull the EFI relay in the same fusepanel and get the same power lose. If so, then that is the EFI feed from that fuse.
That should go the the white/blue (W-L) wire on the 3.4.
Thats what I did anyway.
Old 01-18-2010, 01:47 PM
  #36
Trebor's Avatar
Right i got that one but the 2000 3.4 Ik2 it has a white/red wire and i can't find where it should go.
Old 01-19-2010, 07:04 PM
  #37
dntsdad's Avatar
Well, i tried to convert my PDF to Word doc that could be searchable but that conversion didn't work very well.
I have the full version of Acrobat and one feature it has is to search for text which is really sweet for this. I search the plug i was looking for and found all its instances and then labeled from there. For example, if i was I was looking for allt he wires that passed through junction II3, I entered that into the search box and let Acrobat find them all for me.
You could also look for wires colors by search W-L and it will find all those.
You can get the fully featured trial here for 30 days.
Old 01-19-2010, 07:11 PM
  #38
I'm not familiar with anything splicing into the IK2, let me check my notes to be sure.
Old 01-20-2010, 04:57 AM
  #39
Trebor's Avatar
OK I think i have information overload going on. The wire i need spliced is the W/L (White/Blue) on the IK2. Sorry guys. I got a little cought up on this. Also found a OBD2. But it has 4 wires in it. Is that the OBD1 if so will it still work. Also what is the PTNK.
Old 04-18-2020, 01:08 PM
  #40
filthyphil's Avatar
Originally Posted by dntsdad
Trebor
Hey dntsdad,
I have been working on doing a 3.4l swap on my 1995 T4R and just today got it to fire up and running today, which I'm very excited about! I have the overall EDWs my ECU and Harness (1998 T4R) but I wasn't able to find the overall for the 1995.. From this post it sounds like you did? Or do you have any advice for what i need to look up on TIS?
The truck runs but I still have some blank spots on my swap EDW and this would help a ton!
Appreciate the help in advanced!
Quick Reply: IH2 wiring confusion *PLEASE HELP*
