Hello YotaTech......newbie about to attempt this 3.4swap
Hello again YotaTech my name is Joe....this is my first post and i was wondering if it was possible to swap a 3.4 from a 02 4runner Limited 4x4 with a auto ECM into my 93 pickup 4x4 with a 3.0 and manual trans? i did some research on this forum about what bolts to what...but im worried about how would the wiring be to get this engine going in my 93. ive read that these throttle bodies are drive by wire so will that be an issue.....oh and is it possible to still use the automatic ECM from the 3.4......someone please point me into the right direction.Thanks!
right now im on the hunt for a older computer and wiring harness.....no luck yet tho...Oh and do i also have to swap out the throttle by wire throttle body for an older throttle by cable type? at this point anything helps...thanks
Found an ECM today from a manual trans 5speed 4x4 3.4....Toyota 89661-04310......does anyone know the part number for the matching wiring harness.......or does anyone know tha part numbers for just the plugs? i was just planning to redo my 02 Auto harness to match this 97 5speed.....lemme know thanks
I would try to find them at a junkyard. I called a toyota dealer in my area., and they couldn't get two of the plugs. He said his US warehouse didn't have any so no dealers could get them. That i would have to try japan. I told him to get lost.
the 97 has the 2 row plugs. I know that the bigger plug from your 3.0 will work for one of them. Just thought I would pass this along. I swapped in a 97 4runner into my 90.
I ditched that route when doing mine and went with the runner ECM cause it was much simpler.
I know the plug numbers for that and they are available. Just bought a set. About $10 for the set.
That ecm is a Tacoma i think. Will have erg probably along with fpu and something else. Might want to get a the runner ECM. 89661-3d310. No egr, no fpu or the other circuit I can't think of right now.
@ dntsdad
i called toyota parts dealer of dallas and they quoted me 8 bucks a plug......prices must of gone up i guess....ill jus eat the cost to get this project going......btw do you still have the EWD for the 97 4runner ecm 89661-3d310?
Just started to clean up the motor a bit and just realized that i still have the newer type throttle bodies.....just wondering if i switch it out for a 97 type will the plugs be different?
