a340f Shift lock release
Old 04-14-2012, 02:28 PM
vasinvictor's Avatar
Calling on anyone who has the shift lock release working properly using the doner shifter and doner a340f. The only thread I can find any info about it is Mt.Goat's thread, but the pictures are too small to see what was spliced. The 98 EWD is not making any sense and colors are not matching up. Any help would be appreciated.
Old 04-14-2012, 05:46 PM
ultimase's Avatar
Not much help on this one, I always thought the shift lock release was physical and not electrical. Odd that it suddenly stopped working though, have you taken a look under the car at the actual linkage?
Sorry might be completely off base on this one.
Old 04-14-2012, 06:02 PM
QuickSilver74's Avatar
i always just disable the lock. really dont see the need for it.
Old 04-14-2012, 07:19 PM
How do you disable the lock? Physically remove it? I'm not opposed to it. I've been pushing the button To this point.
Old 04-14-2012, 07:52 PM
pop the cover off, see what is blocking it from shifting and remove it. my Xterra had a little lever that simply pushed off, my civic had a small plastic pin that i used a razor to cut off.
you could just rewire it to stay open but with being constantly on it may burn up faster. i prefer to just remove it and forget it
Old 04-14-2012, 07:56 PM
That's just what I'll do then.
If somebody knows how to properly wire it up feel free to chime in. The wires going out of my shift lock to the solenoids match up with the EWD but the input wires don't match jack squat. I have a Y, R-W, R, L-W, and B for inputs.
I have an extra shifter I can play with later.
Old 04-14-2012, 09:14 PM
cadman's Avatar
I managed to take one picture and make a diagram when I spliced the shift lock connector:
Much of the wire color codes for the earlier trucks are incorrect in the Toyota EWDs, so with a little ohmmeter work this is what it is on my truck.
Old 04-15-2012, 11:41 AM
Cadman I wired it up just like you showed. The colors on my '95 matched up with your '89 too. I heard the relay clicking in the dash, but the shifter button would still not depress.
I got tired of messing with it, so I removed a couple screws on the shift lock actuator solenoid and removed it completely.
After removing it, you still have to depress the shifter button to get it into gear, which was really my only concern about removing or disabling the shift lock. This is satisfactory to me, so it's staying this way.
I'm going to cross post this into my build thread for another search reference.
Old 04-15-2012, 04:40 PM
cadman's Avatar
Your shift lock ECU or the shift lock unit may be faulty, most likely the lock unit if either of the two.
okamikai
04-30-2018 10:19 PM
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
Tykiller1994
08-10-2015 07:49 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: a340f Shift lock release
