5 speeds
Old 07-12-2012, 04:47 PM
sacredmagic's Avatar
5 speeds
What are the differences between the 3.0 r150f tranny and the 3.4 r150f tranny? Do I need to change clutch etc to use on my 3.4?
Old 07-12-2012, 06:18 PM
waskillywabbit's Avatar
Have you done a swap or are going to do a swap? All this is answered in the FAQs and build threads.
:wabbit2:
Old 07-12-2012, 06:37 PM
Did my swap but was an auto the auto also ˟˟˟˟ the bed....so I'm going to change it to a manual! Kinda didn't read much that didn't pertain to auto!
Old 07-13-2012, 05:31 AM
Now you know how to fix it!
:wabbit2:
Old 07-13-2012, 07:50 AM
dntsdad's Avatar
The biggest difference is that the slave is on opposite sides. The bellhousing are totally different also as well as far as how the starter bolts up (starter bolts are not interchangeable) the mounting bolts from the bellhousing to the motor will be different as well due to the lengths.
One is slightly longer if I remember correctly as well but I cannot remember which is longer.
The shifters are not interchangeable either.
I believe the gears are the same or at least similar enough to not be noticeable.
I bought all 3.4 clutch components when i installed the 3.4 R150 and kept it all when I switched back to the 3.0 R150. They are interchangeable. You will have to drill out a starter mount hole if using the 3.0 starter on the 3.4 bell housing.
I have ran both in my swap.
izzmee
08-17-2015 10:20 AM
91yotapup
08-17-2015 09:40 AM
129Creepin
08-05-2015 10:12 PM
kyletbert
07-17-2015 11:39 AM
wilbertd
07-06-2015 07:39 AM
Quick Reply: 5 speeds
