What is necessary to put a 5VZ in my in my 2.7 equipped 97 Taco?
Yep..the dead horse is back..go on beat him. I haven't posted in 6 months! Now I am back at the torch again...I have a 97 Taco..with a 2.7 in it. Its 4WD 5 spd...And I want the 5vz 3.4 in it. Bellhousing the same? Motor mounts? How bout tranny crossmember? The exhaust fairly easy to fab? I know I don't "technically" need the harness and ECU, but it makes it easier! I wonder if I can find the thread where I swapped in a 3. slow in place of my 22re? Yes thats what I did...just cuz I could do it. Anyway I guess thats my only question..motor mounts good? Bellhousing?
No, no, no, no, no, and no. Nothing is the same. Nothing will bolt up.
Search. Theres an entire forum on this engine swap.
Yes, you DO need the ECU and harness.
From the swap threads I've read it seems it's more cost effective to just buy a whole wrecked donor vehicle. + You get other things to sell........or keep.
I saw a lot of custom motor mounts.......going to be harder to find a 5 speed/5vzfe combination than the auto....Need oxygen sensors and exhaust and ECU. There is more I know it....
Buy a doner with a cab you like and just swap it. We did 00regcabs in a weekend. If it wasnt for the bed,cab corners(going standard to xtra cab) it would have drivin out in 2 days.
how we did it. this is a bit more then you were asking but standard cab to standard or xtra cab to xtra cab would be cake
http://www.tacomaterritory.com/forum...d.php?t=115326
Regency
20
01-03-2020 07:43 PM
jasonty
41
12-23-2018 01:00 PM
Avenged
07-09-2015 07:55 AM
