Engine Swaps Swapping an engine in your Toy, here is where to learn how
What to do!! 3rz 2rz or 5vz
Old 05-27-2013, 05:07 PM
jeremy.egli's Avatar
Details:
It has a 22re in it now
Rebuilt front end
Rebuilt the warn hubs andadded a bearing
Bobby long field shafts new 3rd member koyo bearings new seals 5:29
Motor has maybe 1500 miles
Rock ripper cold air
Rev limiter
S10 radiator
Bored .30
hot cam
shaved crank
High comp pistons
Square light Conv( headlights from whole lense to just bulbs)
W56 tranny
knuckles just rebuilt and "beefed" up
Hi-steer
Ifs power steering (new box)
3/4 ton driveline
rock sliders
Brand new Headman header
stainless pipe to flow master 40 stainless to tip
Brand new rear axle bobby longs new 3rd
5:29 Detroit tru-trac just gone through professionally
Blisteins in front
Backing eliminator on knuckles
Probably more I'm just hitting a wall
I want to do a motor swap but don't know what would be a good swap it's my DD now.
I just wanna know what goes into the Diffrent swap and what would be worth doing I don't care about mileage but I'm not doing a 4.7 swap
Old 05-27-2013, 07:14 PM
totally a bro
Staff
vital22re's Avatar
depends on your mechanical and fabrication skills. 3rz, and 5vz are good motors. I've done both not terribly difficult but time consuming. I'd love to do a 1jz motor with turbos if I had a 4cyl to start.
Old 05-27-2013, 07:38 PM
Define fab skills...
I keep hearing about a thrush or thrust bearing in the 3rz that if it goes out you might as well get a Different motor.
If you have a 3.4 swap setup vital ill trade you my 22RED setup haha
Old 05-27-2013, 07:50 PM
totally a bro
Staff
vital22re's Avatar
If you had a turbo'd 1jz or 2jz i'd think about swapping.
Old 05-27-2013, 08:00 PM
You did leave it pretty open when you said "Id love to do a 1jz if I had a 4cyl I would"...
Haha
What all would I need to do a 3rz that I don't have...
Old 05-27-2013, 09:05 PM
This is more correct ha
Do I need a new ECU or anything special for the 3rz swap
Old 05-27-2013, 09:18 PM
totally a bro
Staff
vital22re's Avatar
do a google search. You gotta do the footwork yourself. Your best bet will be to buy a wrecked tacoma and sell off what you don't need.
RyanV
05-14-2016 08:24 AM
LCE_Performance
10-01-2015 01:03 PM
kportercpa
Engine Swaps
09-10-2015 12:08 PM
digdug40
08-28-2015 02:24 PM
mYnAmEiSmUd
07-20-2015 06:48 AM
Quick Reply: What to do!! 3rz 2rz or 5vz
