Engine Swaps Swapping an engine in your Toy, here is where to learn how
Need a little help. Dual timing chain
Old 08-02-2011, 07:26 PM
claybrook's Avatar
Question Need a little help. Dual timing chain
I bought a 22r motor and the guy said he thought it was a 85. I tore it down and there is a dual timing chain in it. I thought they were in 20r. Now im thinking someone already made it a 20r/22r hybrid but not sure please help. I also got to get a rocker arm assembly which one should i use 20r or 22r?
Old 08-02-2011, 07:31 PM
85gijunk4x4's Avatar
dual row timing chains were available in pre-1984 22r's, and also all the 20r's.
possiblity he had replaced the head with a pre 1984 head? or maybe he did go ahed and swap a 20r head on there.
Old 10-03-2011, 01:04 PM
mommucked's Avatar
I think you can install the double chain on any 20 or 22R if you get all the parts,gears,guides, oil pump spacer etc. But Im no expert
Old 10-03-2011, 02:51 PM
xxxtreme22r's Avatar
Flat or domed pistons? Round or pear exhaust ports? Round or square intake ports? And by 22r you mean it's a carbureted engine correct?
I am assuming you want to know so you know which gasket kit to get correct?
Old 10-03-2011, 06:27 PM
snobdds's Avatar
This ^^^
Thats the only way you will know for sure. The ports will tell you what is on there for sure...
Charecter1
11-06-2023 10:08 AM
Yota.Jay
07-23-2015 08:08 PM
bryan34w
07-06-2015 05:53 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Need a little help. Dual timing chain
