FJ60 front axle???
FJ60 front axle???
I recently acquired what I believe to be an FJ60 front axle.
I know nothing about these and was wondering if it would be a good candidate for a SAS on my 1989 Hilux.
Phessor
Phessor
Probably harder to come by is one reason. Also they are set up in a spring under configuration, so you would need to relocate the spring perches for spring over. Also, not sure on the steering arm setup, so you may have less options on the steering as compared to the mini-truck axles if they are not the same. And a different size 3rd member, not a big deal for a SAS, but you will have 2 different sizes front and rear.
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
