93-98 T100s All T100 trucks
97 t-100 check engine on
Old 07-22-2012, 06:28 PM
t-100-truck -driver's Avatar
Hi,folks,I am new to the site.I had my check engine light to come on,so I took it to the local auto parts store and they put an obd 11 scanner on it and the codes 450 and 441 come up.They told me that it could be several things such as the pressure sensor switch malfunction or incorrect purge flow/IT'S funny ,because they won't sure where they are. Can you guys help me on this/Maybe a diagram/
Old 07-22-2012, 06:39 PM
rworegon's Avatar
Use the FSM (Factory Service Manual) link in my sig to get a manual close to your rig. And, start searching this site.
http://www.ncttora.com/fsm/T-100/199...T100%20FSM.pdf
For a '02 4Runner, but it will help get you started:
http://www.ncttora.com/fsm/1996/SIL/...zfe/parloc.pdf
P0441 Evaporative Emission Control System Incorrect Purge Flow:
http://www.ncttora.com/fsm/1996/SIL/...e/cip0441p.pdf
P0450 Evaporative Emission Control System Pressure Sensor Malfunction:
http://www.ncttora.com/fsm/1996/SIL/...e/cip0450p.pdf
Old 07-24-2012, 05:13 PM
Hey RWOREGON, THANKS ALOT .For some reason I am having trouble opening the first pdf file,but what you have given me will help alot.
Old 07-24-2012, 05:26 PM
rworegon's Avatar
The first link takes several minutes to download. It's the entire manual in PDF.
smthwsn357
05-01-2024 07:28 AM
bigjstang
08-25-2021 12:41 AM
sandyota
02-04-2021 11:16 AM
icentropy
09-16-2020 02:47 PM
razorman8669
07-12-2015 12:13 PM
Quick Reply: 97 t-100 check engine on
