93-98 T100s All T100 trucks
4x4 not engaging in low, won't go into high
Old 01-06-2013, 04:45 PM
Montana_Tom's Avatar
Hi guys! I have a 97 T100 Auto w/ overdrive 3.4. I went to use 4x4 the other day and it shifted into low range, moved slow as it should, but didn't lock in 4x4. I tried to go to high range and it won't even go into high range at all, won't even slide back into that notch. Any thoughts? Thanks!
Old 01-10-2013, 06:47 AM
spn
spn's Avatar
what have you tried?
I recently had a similar problem. Is the light on your dash showing that your truck is in 4wd?
If not then check the valves near your washer fluid reservoir. Both of mine tested bad. I replaced them and not only did my shifting problems go away, but my 4wd worked again.
I have pics on my phone that I took. I could get them posted if you want.
Old 01-10-2013, 06:56 AM
I'll check that today! Thank you very much!
Old 12-03-2013, 12:40 PM
Marcia Wilbur's Avatar
spn, could you post the pics? have a '95 that basicly goes into 4wd when it wants to, not when i need it to..
Old 12-03-2013, 12:43 PM
spn, could you post pics? have a '95 that goes into 4wd when it wants to, not when i need it to..
kazuya2416
04-05-2024 02:17 AM
Doug4320
03-24-2018 10:11 PM
Coreyr384
07-10-2015 11:13 AM
Nickdigg
07-07-2015 06:04 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 4x4 not engaging in low, won't go into high
