1995 T100 3.4 5VZ FE Oil Cooler Question
Hello All,
I have a real problem on my hands. Ihave a 1995 T100 3.4 4WD SR5 with an oil leak from the oil cooler.
The correct part # is 1570062041 but unfortunately it has been discontinued. I have contacted a fellow who has a 1999 4 runner with an oil cooler for sale from his 5VZ FE. Do you know if this part will fit? Otherwise any idea where I can get this part new used? My truck has been sitting for 3 weeks now....any help is greatly appreciated.
Thanks to all who respond in advance.
It should work....most all the 5VZ-fe part are interchangeable. You may need to use the Change Vehicle link to more accurately dial in your rig using the link below:
http://www.toyotapartseast.com/Page_...3431,3445,3446
http://www.utoyot8.com/Picture.aspx?...ccode=&ppName=
Is it leaking from the oil cooler itself (cracked/rusted), or it is leaking from behind it? There are three replacable gaskets/seals on the oil cooler. One is internal, one is on the bolt, and the other is an o-ring at the back.
Avenged
07-09-2015 07:55 AM
