General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Switch Wiring Question
Old 09-05-2013, 03:13 PM
ARK_SWAMP_RIDER's Avatar
Edit: decided to tap the tail light fuse and forget about getting them to dim.
I'm getting ready to install some LED lights and OTRATTW switches on my 88 Pickup. The switch has a positive and negative that is used to turn on the backlight on the switch.
When I did this on my 4th gen 4runner, I tapped into the OEM dimmer switch. When just tapping the positive, the switch dimmed, but opposite of the other dash lights. I had to run both positive and negative to the OEM dimmer switch to get the new aux switch to dim correctly.
I was expecting to do the same on my pickup. I don't have the switch yet, I'm just using a multi-meter to figure out which wires are which. On the factory dimmer knob, there is a red/black (+) and white/black (-) wire. Either way I connect these (only connecting + or connecting both + and -, it seems to be working opposite the dash lights. With the dash lights on the brightest setting, I barely get any voltage, but with them on the dimmest setting, I get full voltage.
What do I need to do to get the backlight for the switch to come on only when the headlights are on and also to dim with the other dash lights?
gary4runner
09-24-2015 12:53 AM
88yodabasket
07-13-2015 01:32 PM
Johntom240
7
07-13-2015 12:18 AM
bryan34w
07-06-2015 05:53 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: Switch Wiring Question
