Need wiring help, turn signals
This is on the passenger side, the driver side is in the same boat. I was going to turn the signal on and see which wire had voltage but my flasher isn't ticking. Would the best option be to follow the wires back to the cab?
Find out what wires are the brake and tail light and the back up lights in the back the one left over will be the turn signal.
Your flasher won`t flash without bulbs (a load) in the circuit
it will be the only different colored wire left and right tail lights brake lights and reverse are all the same color left and right.
That wire will be the same color front and rear for your turn signals
Looks like you will get good a soldering if your not all ready.
Yes the grounds can be tied together making sure of a good connection.
Not real sure just what you mean by pairs or 3 together
in the lighting circuit all the lights coming on with the headlight switch are most often the same color
With something that old who knows :jessica::jessica::jessica:
jasonty
41
12-23-2018 01:00 PM
