General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
headlights/reverse lights kill engine
Old 11-27-2006, 12:45 PM
kstoyota's Avatar
i have a 94 t100. i have found that whenever i turn on the headlights the truck automatically dies and if i put it in reverse the same thing happens. I have also noticed that the RPM gauge bounces if i put the blinkers or flashers on. Thanks for any help
Old 11-29-2006, 09:30 AM
L33T35T 4Runner's Avatar
sounds like your alternator or battery arent supply enough juice, and those lights pull enough amps away from the coil to kill the motor. check your battery first then alternator
Old 11-29-2006, 09:39 AM
4Crawler's Avatar
Could be a grounding problem. Check and clean the cab grounds as a starting point.
Old 12-01-2006, 11:16 AM
kstoyota's Avatar
Thanks turns out that it was a bad ground. There was corrosion on one of the wires in the cab. Thanks again
smthwsn357
05-01-2024 07:28 AM
Charecter1
11-06-2023 10:08 AM
ashersullivan88yota
01-18-2022 05:37 PM
06-01-2021 01:51 PM
redneck17
07-17-2015 07:44 PM
Quick Reply: headlights/reverse lights kill engine
