General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
86 4runner 22r extravaganza, wont stay running
Old 10-14-2010, 08:19 AM
boog1487's Avatar
I have a 1986 Toyota 4runner as my daily driver. This thing has done me nothing but good in the 3 years of owning it until now!
Problem: Tries to start and will start for a second or two, but then will stall out and even trying to gas it and keep it going it will still stall out. Every once and a while it will run fine for a few days and then all the sudden it will leave me sit. Then I trailer it home and try new things then it will run again for a few more days and leave me sitting once again.
Attempts: I have tried fixing just about everything that i could think of. I put on new of the following...
. Fuel pressure regulator
. Fuel filter
. Throttle positioning sensor
. Cap and rotor, plugs and wires
.... I have my egr valve unhooked but i have been driving it that way for two years previous to this extravaganza.
Overall: It has fuel pressure going into the injectors, has plenty of spark. I have cleaned all the grounds on the whole rig. My old man seems to think that there is some kind of electrical disaster. No check engine light is on.
Help: If anyone has any tips or tricks to try and diagnose my problem or may have any idea on what it may be i would be more than happy to try it out cause I love my 4runner and want it back on the road. THANKS
Old 10-14-2010, 10:21 AM
myyota's Avatar
I had a similar problem on my 86 4Runner, its was running good one day and the next day nothing, it wouldn`t start. It would try and start if i sprayed some carb cleaner into the intake but would die soon after. I had fuel presure and spark and checked everything i could, but i could find nothing wrong. I had a spare solenoid resistor and i decided to try it because nothing else so far had worked, and it started on the first try. Maybe that part had been going bad for a while, because it was hard to start sometimes, and now it starts every time.
Old 10-15-2010, 04:37 PM
boog1487's Avatar
Thanks man ill give that a try this weekend. Funny thing is though with my 4runner is that it seems to not run if it rains or if it is really humid almost like moisture is an issue as well.
Old 10-16-2010, 12:36 PM
boog1487's Avatar
is that the resistor on the passenger side that is right beside the starter relay?
Old 10-16-2010, 03:25 PM
myyota's Avatar
Its mounted just behind the fuse box under the hood, it aluminum with fins on it.
Old 10-17-2010, 11:01 AM
boog1487's Avatar
ight thanks
Old 10-17-2010, 11:02 AM
boog1487's Avatar
was your problem moisture related?
Old 10-17-2010, 12:33 PM
myyota's Avatar
No, ive never had a problem with moisture. Just throwing an idea, but its possible that the fuel pump might be bad, have you tried checking that ?.
Old 10-18-2010, 02:09 PM
boog1487's Avatar
yea fuel pump and fuel filter were the first two things that i went to that pump works great even when the thing is acting up...
boog1487's Avatar
i put on a new resistor just have to see if the rain effects the rig still
Old 10-18-2010, 04:45 PM
myyota's Avatar
Did you buy a new resistor or did you have a used one ?.
Old 10-20-2010, 01:31 PM
boog1487's Avatar
no i got a used one from a junk parts truck my buddy had it rained yesterday and didnt fix the problem
Old 10-20-2010, 01:32 PM
boog1487's Avatar
when it rains this rig is down any ideas from anyone.......?
Old 10-20-2010, 03:56 PM
myyota's Avatar
When it rains does it seem like the injectors arn`t firing ?. Im going to throw out a few other things for you to check. In the fuse box behind the driver side kick panel check the EFI and ignition fuse, sometimes they get corroded and your 4Runner won`t start, i had this happen to me on my 86 4Runner. Another thing that happens on our trucks is were the wires for the injectors are spliced together, they will corrode and break. So try the fuses first before getting into the wiring harness.
Old 10-27-2010, 04:12 PM
boog1487's Avatar
thanks man i am trying everything this thing is still actin crazy
Old 11-28-2010, 05:48 AM
boog1487's Avatar
computer has been down... it ended up being the e.c.u. got a new on slapped in and it has been running great ever since rain, snow, sleat, or hail
Ichneumon
09-27-2015 04:21 PM
bigblue82
10
07-06-2015 08:27 AM
B. Graves
07-03-2015 04:10 AM
thelifeadventure
07-02-2015 03:09 PM
serenity03k64
06-27-2015 07:59 AM
Quick Reply: 86 4runner 22r extravaganza, wont stay running
