YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-21-2008, 08:56 AM   #1 (permalink)
83
83's Avatar
Front Driveshaft
I've been told my front driveshaft has a binding spot and needs to be rebuilt. I feel like I used to know this stuff back when I had my last Toyota....but it's faded...When I'm not using 4wd, is the front driveshaft turning? Right now I just want to get this truck running so I can sell my car. It's going to be my DD. I'll need 4wd in the winter, maybe sooner if I take the truck out on some trails, but I'm just wondering if the front shaft is something that can wait, or if it needs to be done right away. Rebuild is expensive..
83 is offline
Sponsored Links
To remove this ad, register today!
Old 07-21-2008, 08:57 AM   #2 (permalink)
dirtoyboy's Avatar
shaft only turns in 4wd....you can always pull the shaft and run 2wd til you can afford the work
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
I'm the yota junk man......PM me for ALL your parts needs NEW or USED
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 07-21-2008, 10:38 AM   #3 (permalink)
83
83's Avatar
Thank you again!
83 is offline
Old 07-21-2008, 11:00 AM   #4 (permalink)
85toy's Avatar
make sure you hubs are unlocked.
__________________
1984 toyota pickup extended cab 4x4
couple of mods
85toy is offline
Old 07-21-2008, 11:05 AM   #5 (permalink)
dirtoyboy's Avatar
Whats wrong with your shaft?
bad u-joint?
__________________
Old 07-21-2008, 01:45 PM   #6 (permalink)
83
83's Avatar
Ok.
I actually don't know what's wrong with it.....when I bought the truck I brought it in to a local "Toyota's Only" shop and they printed me out a list, in order of priority, of what was wrong with it. One item was "front driveshaft has a binding spot, needs rebuild" or something very similar to that. That's really all I know. I'm just going down the list...
__________________
Zach
'83 Shortbed currently under construction..
83 is offline
Old 07-24-2008, 09:09 PM   #7 (permalink)
could it be, "front driveshaft has a binding spot, needs lubrication..."
anotherjeff is offline
Old 07-24-2008, 09:27 PM   #8 (permalink)
4Crawler's Avatar
Quote:
Originally Posted by 83 View Post
Ok.
Check it out yourself. How? Lay underneath the front end and turn the front shaft by hand (t-case in 2H and front hubs unlocked). Should be able to feel it it is binding. If so, see if you can isolate where the binding is occurring.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 07-25-2008, 06:12 AM   #9 (permalink)
83
83's Avatar
Ok. Isolate it and..............?
I'm guessing if all it needed was lubrication the mechanic would have said so, he doesn't do the rebuilding and he's a good mechanic so it's not like he's trying to make extra money off me.
Thanks!
__________________
Zach
83 is offline
Old 07-25-2008, 06:19 AM   #10 (permalink)
4Crawler's Avatar
Isolate the source of the binding, if it does exist, and then fix it. How to isolate the problem? Unbolt the driveshaft and run each joint through it's range of motion and feel for any binding, grittiness or slop and if found, that is likely the cause of the problem. Might be a u-joint gone bad, easy enough to replace. Might be the CV joint, a little harder to repair.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 07-25-2008, 07:58 AM   #11 (permalink)
83
83's Avatar
Ok, thank you.
__________________
Zach
83 is offline
Old 07-25-2008, 02:24 PM   #12 (permalink)
The hardcore details @
http://personal.utulsa.edu/~nathan-b.../3propelle.pdf
If needed, all of the U-joints, including the Double Carden, are available at the usual outlets (PartsAmerika, 'Zone, NAPPY...). A big vice will help. A press more so.
Once it's out, do it at your leisure. The money you save by doing it yourself can be spent on tools!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
front driveshaft lowfrankie Items Wanted 3 05-24-2008 08:03 AM
FRONT driveshaft camo31"10.50" Pre 84 Trucks 12 03-08-2008 01:27 PM
DAMN front driveshaft!!! 4Runner92sr5 Solid Axle Swaps, All Years 15 07-24-2007 09:32 AM
Front Driveshaft Homeless dog & truck Axles/Suspensions/Tires/Wheels 0 01-03-2007 02:38 PM
Front driveshaft Homeless dog & truck Engine/Tranny/Parts 0 09-28-2006 04:10 PM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.1.0
2002-2008 Yotatech.com
