Fake/Upside Down 3VZE Head Gaskets!
Old 05-02-2012, 12:58 PM
  #41
clocklaw's Avatar
Originally Posted by MudHippy
Better yet, can you SHOW me what you mean? As in
You're kinda lacking in the sufficient evidence to form a valid opinion department, so far.
I am presently working to diagnose the reason therefor it is mere speculation at this point.
If you want pictures and a back story, you'll need to click on the link I provided and take a look at them in the reference. When I have formulated a good hypothesis that I feel is reasonably sound, I will post my conclusions in that thread.
Old 12-07-2012, 11:36 AM
  #42
MudHippy's Avatar
More fuel for the fire...
The latest addition to the story goes something like this...
Some time ago I asked myself the question "I wonder if anybody(specifically Victor Reinz) still makes the original style(w/o Slipperplate™/expanded bore grommet) 3VZ-E head gaskets?". I'd remembered reading about Victor Reinz still making some for the 22R-E previously. And that they'll supposedly still do the just job as well, or better, for 22R-Es(and/or potentially those originally on my 3VZ-E) than the Slipperplate™/expanded bore grommet type also being made for it(and the only type known to exist for 3VZ-Es). So...
I've eventually I've gotten around to doing a bit of the research to see if it's even possible they exist. Which, so far, does suggest the possiblility that Victor Reinz MAY actually make a similar style/type of HGs for the 3VZ-E. Since they do make some type of HGs for it. Exactly which type they are? With a Slipperplate™/expanded bore grommet, or not? We'll see I guess? Somebody will have to provide more than what I've found. But here's what I've got so far...
Victor Reinz #54186
Victor Reinz #54185
So...those must be either a type/style w/o Slipperplate™/expanded bore grommet(like the ones they make for the 22R-E). Or, if they do have a Slipperplate™/expanded bore grommet, it must be on the head facing sides of the gaskets. Because what is shown in the pics above are the block facing sides. Whichever type/style they are, the following has been stated regarding:
Gasket design: Fiber composite
Material: Nitroseal
• Stays cool at temperatures up to 1,800° F
• Doesn't know how to relax... no re-torque required
• Maximum heat transfer keeps your head (& manifold) straight
• Coolant, fuel and oil... no problem
• Designed to seal minor surface irregularities
Victor Reinz Web Catalog
Old 01-15-2013, 12:56 PM
  #43
west_89_'s Avatar
Hey everyone! Ive been doing a lot of research on head gaskets, as I'm doing one in my 92 4Runner. One thing I've noticed in all threads related, from yotatech or other form sites is everyone has there own opinion on which aftermarket HG is the best to use. Also I've noticed that lots of people have a horror story of when they installed/had installed a new aftermarket HG that only went 10k, 15k, 30k, etc...
Whether the HG was from a reputable company, parts store or bought through eBay people have their horror stories....... All i can say is doing the HG is a finicky thing that takes time to do properly. More often then not people rush this job not follow every step from the FSM properly or even skipping steps!!! When re-surface the head check that it meets the specs for your specific HG (they change for HG to HG). Some HG's (depending on the material) need to be re-torqued after so many miles (this is often skipped as well).
Just remember not everything you hear is true. Its essayer to blame a faulty part then it is to blame a poorly done job.
(Please dont take this to heart, I just feel it something that never said but should be.)
Old 01-15-2013, 02:14 PM
  #44
ROCKLAND TOYOTA's Avatar
one should ALWAYS use OEM toyota gaskets when replacing things. Might cost more BUT you'll never have a problem. 3VZE complete gasket kit(v/c to pan) costs right under $300 BTW....
Old 01-16-2013, 02:33 PM
  #45
west_89_'s Avatar
I prefer an MLS to and OEM, as the OEM is made of graphite and will deteriorate over time from oil. Plus the MLS HG's don't need re-torquing. But like i said each to their own.
Old 01-17-2013, 03:42 PM
  #46
Mls???
Old 01-17-2013, 03:53 PM
  #47
Swimmerboy2112's Avatar
This is the reason that I ALWAYS use Toyota OEM stuff when the engine is concerned.
Old 11-12-2014, 04:17 AM
  #48
imfoolishyet's Avatar
I realize that this thread is pretty old, however, the DNJ Rock full gasket kit I opened yesterday for my 95 4Runner contained the upside-down head gaskets. I have received great products from them in the past and was quite surprised to find this. I will keep you posted how their customer plays out on this matter.
Old 12-28-2015, 09:53 AM
  #49
MudHippy's Avatar
Not that I didn't believe you, because I did, but I just ordered some too. And got the same results.
Which sucks. Since I won't use them. Or any that aren't of the older Rock or Ishino design. Wish me luck finding some. All other brands appear to have gone to the upside-down version now too. I may have to try the Victor Reinz(like OG OEM style found on my 88 possibly?)...if all else fails. My theory has pretty much evolved to "Toyota hasn't done anything right since 1988" anyways. Every design change they've made since then is/was just to cut corners IMO. Make it weaker for cheaper.
I'll post some pics later of these newer DNJs. They look even worse quality than the Evergreens. Which I still have. I'll have to compare them side-by-side.
I wonder what would have happened if I hadn't gone and said anything/started this thread. Would there still be both styles available? Being as what I really proved in the end here(and decades after the fact to boot) was that the newest OEM style really are "upside-down"(compared to the previous OEM design). So why would anyone be trying NOT to imitate the latest OEM style? Now that I've gone and unveiled the truth about it FOR ALL TO SEE(26K+ views). Looks like I went and shot myself in the foot on this one. Nice!
BTW, how did that go for you? What did you do with them? What did they have to say about it?
On the MLS talk...get real. It's not so easy as just installing them and having them seal. There's more time/$ to it than that(esp. in comparison to installing other styles of HG). Next, EVERYTHING in the Universe deteriorates over time(from something). It's called entropy( it). Now, show me a graphite HG that clearly shows deterioration(better yet, having failed) from being in contact with oil during use(good luck with that!). And you DO NOT retorque the HGs on a 3VZ-E. You my friend have MUCH research to do still. Come back when you have a clue what you're talking about eh?
Old 12-28-2015, 02:23 PM
  #50
MudHippy's Avatar
On second thought, I'm thinking I'll probably run the damn things just to prove a point. What point? We'll see I guess. Is "upside-down" really worse? Better? Basically the same? Not even as good as the originals(with no Slipperplate™)? Who knows? Not me...not yet anyway. And I suspect I may never. Far too many miles for me to drive in what's left of my lifetime, most likely. Only got just over 20K on the old style Rocks I installed on my 88(whatever many years ago that was). At that rate, and/or unless they fail pretty quick, it don't look too promising. And whichever kind I put on my 90, that I'm gathering these parts to rebuild, will only take that much longer/many more miles to prove anything. One guy, two Toyota trucks. Can I wear either one out? Or will they both eventually wear me out? I dunno. But it sure sounds like fun!!!!
Anyhow...
Here's the "new" DNJ Engine Components(no longer DNJ Rock) 3VZ-E HGs.
Man...I still don't know if I'm brave enough to try these though. It makes the most sense to me that the Slipperplate™ should face the best conditioned surface. Which, unless you're going to have the block resurfaced, is going to be the heads(resurfaced or not). And I don't like the idea of resurfacing a block. So far as I know it's bad idea entirely. I'm still not entirely sold on resurfacing the heads. Definitely no reason to if you're going to run HGs without the Slipperplate™ facing the heads. You could resurface the heads/block with a chainsaw, and the graphite-only side would still seal it. Which is why, I think, it should always face the block. If you're not following what I'm saying. Sorta confusing. Even more so the fact that either the heads or the block needing resurfaced is usually due to having used any kind of non-MLS HG previously. Which ALL do damage to the sealing/mating surfaces of either the block or the heads(or both) while in use. Like a thousand little needle marks strewn across the surface(s). If you've seen it...you know exactly what I'm talking about. It's not pretty. And I want to do more of this because...? Not like there's much choice I suppose.
Old 12-28-2015, 05:23 PM
  #51
millball's Avatar
I am currently building a a 22RE.
Both the head and the block deck are freshly surfaced.
I have a graphite with slipper plate type head gasket- pedigree unknown; it might be a cheapy Evergreen, I don't remember for sure.
Slipper plate is on top-toward the aluminum head.
The Ishino-Stone gasket set I bought came with a graphite gasket with no slipper plate.
I have used many plain graphite type head gaskets on Ford/Mazda and on other similar aluminum on steel engines with long lasting success, so I'm leaning towards installing the plain Stone graphite gasket on my fresh engine.
Any comments, or contrary suggestions from anyone????
Old 12-29-2015, 06:18 AM
  #52
snobdds's Avatar
The slipper plate style head gasket was Toyotas answer to the friction caused on the gasket by two metals expanding and contracting at two different rates. The 22re doesn't have as much issues as the 3VZ-E, but it still could pose a problem.
Why not go with the Toyota head gasket. It's pretty cheap and proven?
Old 12-29-2015, 06:22 AM
  #53
MudHippy's Avatar
I like the way you think. For the most part. My main worry with resurfacing blocks is the potiential need to use a shim/spacer to gain piston to head clearance. They tend to get pretty beat up(compared to heads). The ones I've seen would need a lot of material removed. Which could be the case with the heads too. But removing enough material from either, or both, to need a shim/spacer just adds another component to possibly fail IMO. Since using them gives you 4 more additional surfaces to seal.
I should also add that I have no proof that the Ishino HGs for the 3VZ-E do indeed have the Sliiperplate™/expanded bore grommet. They might not. From the pics, it either faces the head, or doesn't exist. It's been difficult for me to find much info on them. Just the pics, and this little snippet.
The 3VZE engine is experiencing possible "head gasket" problems. The dealer has been covering the first repair up to 100,000 miles driven, but they are not covering the second head gasket repair. From 061705 our head gaskets are of the latest design change, containing the OE Sanwa made head gaskets, 11115-65033 and 11116-65033. But the actual problem is with the head design. Prior to 061705, our head gaskets, were made by Ishino, and were designed based on the 11115-65031/2 and 11116-65031/2, which will work just fine.
Hold on, I just found this too. Which supposedly shows "Stone 11116-65031", the same part # as the Ishino HGs. Which is of the other side(not previously shown in this thread) of the Left HG. And it appears to confirm that they(Ishino/Stone HGs for the 3VZ-E) DO NOT have a Slipperplate™/expanded bore grommet. As I previously assumed they did.
http://www.autohausaz.com/pn/1111665031
I beg to differ.
1. It wasn't Toyota's answer. They stole the idea(I proved that earlier in this thread).
2. The 22R(E) is the engine with the major HG issue. The 3VZ-E HG issue is a myth. The Slipperplate™ was originally designed for the 22R(E), to solve said issue.
People have just assumed it would be good for a 3VZ-E too.
3. Toyota has no clue when it comes to HGs. All they do is keep changing their minds. 4 different 3VZ-E HG part numbers? I mean come on. They're clueless.
Old 12-29-2015, 06:41 AM
  #54
millball's Avatar
I bought a set of Nippon Piston Ring pistons that have been faced .012in on their tops to bring piston protrusion back into spec after block decking, so no need for any spacer.
I am trying my best to build my engine as carefully as Toyota did.
Old 12-29-2015, 07:47 AM
  #55
snobdds's Avatar
I beg to differ.
Regardless of who Toyota stole the idea from, it was "their" answer to "their" expansion problems.
I also beg to differ the 22re had head gasket issues. They had timing chain issues that led to head gasket issues. The 22r with the double row timing chain never had head gasket issues because they never timing chain issues. Many see the correlation between the two, but never understood the causation. Antifreeze contaminating the oil is what killed the head gaskets.
Old 12-30-2015, 04:47 PM
  #56
MudHippy's Avatar
1. You are right...I suppose. But it doesn't make them, or "their" upside-down version of the design, right.
2. Beg all you want. But it's not even debateable. Search this site for "22R-E head gasket failure" threads. Then "3VZ-E head gasket failure" threads. Wonder why there's several hundred more of one than the other? I don't!
I just emailed engnbldr today about this. Here's how that played out:
Hey, can you guys get me some 3VZ-E head gaskets with the Slipperplate facing the heads? The whole world, including DNJ Rock(or whoever the hell they are now) has gone bassackwards on me since the last time I needed some. Now I don't know where to get them, if anybody still makes/has them, or what I should use instead. I didn't know I was supposed to stock up before they vanished off the face of the Earth. Or I would have.
Help me Obi-Wan Kenobi...you're my only hope!
Hi.
I wish I could since the last most recent update on the design, no one makes them the old way any more. Of course the “Slipperplate” design was my own, that applies to the 22R/RE head gasket.
The idea is that during thermal expansion, the steel facing allows the metal to expand and slip.
Engineering says the only reason for steel on the 3VZE since the aluminum is a different metalurgy and does not expand the same is to retain the gasket integrity.
Less costly to do them all one way is the current theory, so far it seems to work all right.
Sorry, no source here, either, kind of wish I did, I could sell the dickens out of them.
Ted
So "it seems to work". That's slightly less depressing to hear...I guess.
I'm still thinking it's a total disaster in the making. Might just have to go to MLS afterall. What a nightmare...
Old 12-31-2015, 02:17 PM
  #57
MudHippy's Avatar
I'm going to try a couple other possibilities. Just to be sure where we're at here. I found some from a couple different sources that look like they might be what I'm after. Both have graphite sides towards the block at least. So there's a 50/50 chance there might be a Slipperplate on the other. And they're a lot cheaper than the Victor Reinz. Now I just have to order some and find out.
We'll see if I turn any up....no pun intended.
Old 03-01-2016, 06:30 AM
  #58
MudHippy's Avatar
I did manage to find some with the Slipperplate™ towards the head. Could be one of the last remaining sets of their type and brand too. It looks like there's another set available if you know which 2 sites to go to. One site has the L and the other site has the R.
They're Apex brand. And are nearly identical to the original Rock design. Structural/design wise they're totally identical. In fact I believe they actually are rebranded original style Rocks.
Anyhow, I think I might be saving them for later and going with the Evergreens or the new Rocks on my next rebuild. Just to prove a point.
There's still some of another brand/design on ebay that I haven't seen both sides of yet. They might have the Slipperplate™ towards the head too. And there's a couple guys selling them. So there's quite a few of them to be had. Thing is you have to buy the whole rest of the set they come in. Since they don't sell them separately. The set is cheap enough that the rest of the gaskets in it could be considered freebies though. IOW, it's the same price as a cheap set of head gaskets anywhere else.
Here's those.
Old 03-09-2016, 08:55 PM
  #59
wadester33's Avatar
gaskets
Damn I'm glad I saw your post,I was hours away from buying some of those off cl thank you
Old 03-10-2016, 05:13 AM
  #60
MudHippy's Avatar
You're welcome. I'm not sure for what. Good luck with whichever path you choose. But you probably won't need it. Since though there may be many different brands/types, there doesn't seem to be much substantial evidence showing one brand/type is any better/worse than another. Which may be because they're all relatively good variations of the design. Or, as I've said time and time again, because the 3VZ-E doesn't really have any major problem related to head gaskets anyway. It's one of the biggest internet myths ever propagated. So any head gasket you put in it will probably work just fine.
Quick Reply: Fake/Upside Down 3VZE Head Gaskets!
